will a KMS 14mm lift valve spring hadle skunk2 stage2??
i install some sk2 stg2 cams and i hear something tapping inside im head...i adjusted the valves and still same thing....so im probaly thinking that it's my valve springs or retainers...im using a 14mm lift valve spring from KMS,and plus KMS retainers too....if i use stock cams then i have no tapping noise..... anyone ever use KMS valve springs before??
small lobes and s2s2 are just that, small (lift) Shouldn't be much of a difference on low cam vs oem. (atleast i wouldnt think anyhow).
I dont know the difference in ramp on the oem vs. s2s2 on the primaries? Anyone?
when i ran the s2s2 in my car a while back i had portflow springs and retainers, my engine made that same ticking noise from the valve cover. we did a val;ve adj. but it still did it, i think it is just normal man. probably from the stiffer springs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20vtech »</TD></TR><TR><TD CLASS="quote">i install some sk2 stg2 cams and i hear something tapping inside im head...i adjusted the valves and still same thing....so im probaly thinking that it's my valve springs or retainers...im using a 14mm lift valve spring from KMS,and plus KMS retainers too....if i use stock cams then i have no tapping noise..... anyone ever use KMS valve springs before??</TD></TR></TABLE>
afaik, kms doesn't make anything they sell..... better find out wtf you really bought.....
anthonylee29
Apr 19, 2005 11:01 AM
