speedo question 94-7 accord
Old Dec 20, 2005 | 07:27 AM
drktorn's Avatar
Default speedo question 94-7 accord
on the rim thread, someone mention bigger rim affect the speedo reading. the bigger the rim make speedo read higher or lower?
Old Dec 20, 2005 | 08:11 AM
YeuEmMaiMai's Avatar
Default Re: speedo question 94-7 accord (drktorn)
bigger tire/rim combo = lower than actual speed
smaller rim/tire combo = higher than actual speed
edit: clarified post
Modified by YeuEmMaiMai at 5:18 PM 12/20/2005
Old Dec 20, 2005 | 02:15 PM
P_Adams's Avatar
Actually, If you ask the anally retentive among us; the rim diameter has no effect on the speedo measurements, it's the TIRE DIAMETER which determines speedo calibration accuracy.
If you've a tire of a 28.5" diameter, the speedometer will see no change - no matter what size rim is inside it.
The rule?
Larger the tire (diameter) the slower the Speedometer will read for a given speed.
Smaller the tire (Diameter) the faster the Speedometer wiil read for a given speed
P
Old Dec 20, 2005 | 05:50 PM
civicboisi's Avatar
Default Re: speedo question 94-7 accord (P_Adams)
^^^ very true
supra360
Nov 10, 2008 06:24 PM
spicoli
Jul 20, 2004 08:19 PM
dclub01
May 24, 2003 07:45 PM
B2FiNiTY
Nov 5, 2002 10:45 PM
