Transmission problems
Old Dec 20, 2005 | 06:42 AM
vc's Avatar
vc
Default Transmission problems
In early november my car started to lock 5th gear (20% of the time), once it locks I can't get into any other gear no matter how hard I try to put it in gear.
Yesterday I was driving home from work and it wouldn't go into 5th (80% of the time). It went in once in 5th, couple of seconds later I was driving and suddenly my shifter just pop'ed out of 5th.
and now my 3rd gear is starting to grind (5% of the time) as well.
I have a gsr tranny /w act clutch in a 92eg.
Old Dec 20, 2005 | 08:14 AM
snatch's Avatar
Default Re: Transmission problems (vc)
Maybe a bent shift fork? Definitely sounds internal to the tranny, and it's going to need some work.
Popping out of gear alot of times has to do with the shift fork being bent, and the fact it won't always go into 5th leads me to think that maybe it's a result of the bent shift fork because it's no longer properly aligned.
Old Dec 20, 2005 | 12:05 PM
vc's Avatar
vc
Default Re: Transmission problems (******)
So I have to take it to the dealer? Internal tranny problem sounds like its going to cost alot.
Old Dec 20, 2005 | 12:46 PM
nocturnaldragon's Avatar
Perhaps some worn syncro's.
And yes dealerships fixing your trans are going to cost you a lot, your better off getting a ussed trans and slavaging parts from it or swaping in the ussed one altoghter.
Old Dec 22, 2005 | 05:22 AM
vc's Avatar
vc
Default Re: Transmission problems (nocturnaldragon)
Do any of you guys think it could be a release bearing.. I'm going to replace my tranny fluid today and see if that would help.
Old Dec 22, 2005 | 12:40 PM
snatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vc &raquo;</TD></TR><TR><TD CLASS="quote">Do any of you guys think it could be a release bearing.. I'm going to replace my tranny fluid today and see if that would help.</TD></TR></TABLE>
Doesn't really sound like a throwout bearing. It sounds more internal to the tranny. As nocturnaldragon said, you're better off sourcing out a transmission somewhere and buying a used one. Keep driving it though since it works for now, just be careful with it. I wouldn't run around banging gears.
Old Dec 22, 2005 | 12:42 PM
kihun_cha's Avatar
see if ur leakin any **** from trany fluid
i had my seal broken so it used to lock up like that
Old Dec 22, 2005 | 06:33 PM
FF-Greg's Avatar
Default Re: (kihun_cha)
damn hope u get it fixed man.
Old Dec 22, 2005 | 06:58 PM
sohctodohc's Avatar
Default Re: (FF-Greg)
all i got to say is if you buy a used tranny be careful and dont get screwed over....is a bitch.
BULL3TPR00F
Feb 14, 2012 10:00 PM
SkiLLzWheeLz
Feb 6, 2012 11:27 AM
Rod.
Nov 11, 2004 09:05 PM
AgentUT
Apr 18, 2004 06:39 PM
