need STOCK del sol 1994 wiring diagram!
Old Dec 19, 2005 | 08:11 PM
rysingsun86's Avatar
Default need STOCK del sol 1994 wiring diagram!
Previous owner screwed up the wiring so i need a diagram to wire them back up again. Right now i assume there is no pwe b.c the lines are just outta whack i dunno whats going on with them. ty
any1 have 1 or might be able to help me?
Old Dec 19, 2005 | 09:25 PM
hatchi's Avatar
Default Re: need STOCK del sol 1994 wiring diagram! (rysingsun86)
wiring for where?? underdash? engine?
Old Dec 19, 2005 | 09:57 PM
DELusionalSOL's Avatar
It will be easier if we know which diagram you need. I have a 94 Del Sol also and I've found that the Haynes Civic/Integra manual's wiring diagrams work just fine. The Del Sol is just like a Civic so I use the Civic wiring diagrams for anything non-engine and I use the Integra diagrams for the engine since I have a b16. Its not 100% perfect but its pretty freaking close. I hope this helps you out. If you have a specific wiring question then let us know and I'm sure someone can help, but its kinda difficult if you don't tell us what the problem is.
Old Dec 19, 2005 | 10:34 PM
Sorry i wasnt detailed let me apologize for the confusion. Here i shall elaborate the engine wiring and the in dash wiring i need the whole run thru. Thank you
Old Dec 20, 2005 | 09:23 AM
b
u
m
p
Old Dec 20, 2005 | 09:31 AM
Del Sol SiR's Avatar
Pep Boys Supercenter
6101 Metropolitan Ave, Flushing, NY 11385
(718) 497-7999
has shop manual with a diagram in stock, so i hear...
Old Dec 20, 2005 | 10:17 AM
negative they dont have 1 i jus called ;[[[
davidthongnguyen
Jul 30, 2003 05:12 AM
