Bent the Rear so-called "K-frame"
Old Dec 19, 2005 | 06:34 PM
MtbikingKing's Avatar
Default Bent the Rear so-called "K-frame"
i was doin some rallying on some back roads and went off the road on an s-turn that i took too fast and hit a rock . . . boulder . . . IT WAS HUUUGE!!! . . . nah i think it was just as big as a granite curb cause thats how much damage it did. Luckily i still had momentum when i hit it so i just kept on goin cause i didnt wanna get stuck in some ditch on the side of the road.
AAAnyways i bent the rear lower left control arm (theres a mouthful) from the looks of it before i stuck it on a lift. BUut unfortunately i bent the metal black box-like piece that bolts onto the unibody in between the two left and right control arms. I heard someone make up a name for it calling it a "rear K-frame" since there was basically the same thing up front.
Now when i told a couple salvage yards i basically had to describe it to them cause they didn't know what i meant when i said "rear k-frame"
#1 I'd like to know what that piece would be called in technical terms so i can try searching for it online
#2 Where would i find an oem replacement relatively cheap online??
and #3 HOW DO U GET THOSE BLOODY LEFT AND RIGHT FRONT CONTROL ARMS OFF?!?!?! cause the freakin bolt doesnt wanna come out even with a 12 ton press!!!!
Old Dec 19, 2005 | 06:51 PM
Ross 2.0's Avatar
In a Junkyard near you.
#1 slow down
#2 I call it the rear sub frame. That's probably how you will find it in a non Honda specific junkyard.
#3 you need a big hammer to beat those ball joints loose if that's what your talking about. I'm not kidding. I use a 3 pound sledge hammer to beat them loose (hit the control arm not the stud)
circapunk
Suspension & Brakes
Apr 22, 2009 01:15 PM
mingbling96
May 30, 2006 01:18 PM
MtbikingKing
Suspension & Brakes
Dec 21, 2005 09:23 AM
Pyrokinetik
Jul 20, 2003 04:12 AM
