Suspension & Brakes Theory, alignment, spring rates....
rear strut question
Old Dec 19, 2005 | 05:14 PM
4DRmafia's Avatar
Default rear strut question
alright well i was wondering if there any oem short strut in the rear ? shorter ones for the ef hathcback ? i already have 89 accord front strut in my ef hatchback and it ride perfect. So is there any shorter ones for the rear?
Old Dec 19, 2005 | 05:40 PM
CRX Lee's Avatar
Default Re: rear strut question (SkipMic2006)
An Accord rear shock will not fit an EF because the span of the rear lower clevice mount is too narrow. The rear EF shock is short enough already that the car can be really much lower without having a length issue normally. The front is where the issue is and you have already addressed that with your front. I do hope you are are using a coil-over sleeve system or some way to make the two different spring perch shapes between the Accord and the EF or together reasonably.
Old Dec 19, 2005 | 05:52 PM
4DRmafia's Avatar
I am using coil overs at 4 corners. I just have a thing for riding low so i was just wondering is there any rear struts that are alittle bit shorter than ef struts.
Ef_u
Feb 5, 2015 12:29 PM
Saam
Oct 4, 2011 10:08 PM
chase7687
Suspension & Brakes
Nov 3, 2009 06:48 AM
whiteguyndahood
Nov 25, 2006 08:01 PM
