CRV window washer not working....Please help!!
Just refilled my GF's 03 CRV window fluid cause it was totally empty....now it won't come out at all.... any idea?? Could I be putting too much in? Cause I fill it up all the way....... Anyone? Please help! Thanks in advance
If it was totally empty, it could just be air in the system. Keep pumping it until it purges out. You can't put too much in because it will overflow anyway. No harm done...just messy.
Have someone stand near the washer fluid reservoir while you try to use the washers. If there is no humming sound, something is wrong with the washer fluid pump. If there's a hum but no fluid coming out, the nozzles are likely clogged. They're easy to pop out but sometimes they can't really be unclogged, in which case you'd have to spring for a new set from the dealer.
TooManyTickets
30
Jul 16, 2007 09:45 PM
