accord problems
Old Dec 19, 2005 | 02:18 PM
accordtype R's Avatar
Default accord problems
i have a 2.2 and the engine idles at about 1500 and surges sometimes i think its the IAC valve or electronic idle control but im not big on diagnosing hondas im a ford guy someone please help a brother out
Old Dec 19, 2005 | 02:38 PM
Ross 2.0's Avatar
In a Junkyard near you.
The IAC valve is always near the Throttle body. Take it off and clean it out good. Also be sure your coolant is topped off. It would be helpful to know what year it is.
Old Dec 19, 2005 | 03:02 PM
P_Adams's Avatar
Default Re: accord problems (accordtype R)
Agreed, I'd suspect the IACM (Idle Air Control Motor). Not only does it get dirty, but it can also develop an internal vacuum leak; which can cause the "hunting" that you're describing.
For more specifics on a potential fix for this leak; you might PM deserthonda. I believe he spoke of this not long ago
P
Old Dec 19, 2005 | 03:05 PM
Default Re: (MooGoCow3)
ya my car is a 94 and i did jus replace a heater hose and did a coolant flush so it could b the coolant low thnx
Old Dec 19, 2005 | 04:25 PM
H23Si_PRELUDE's Avatar
Default Re: (accordtype R)
yeah I have a 94 EX too, the stock 2.2 in it... Mine's been idling wierd to, like tonight I was sitting in the parking lot and it drops down to 500 and surges to 1200 and back down. It needs a tune up desperately, probably an oil change too. I hope nothings wrong with the vacuum hose or anything like that...
Nicholas Mudd
Sep 29, 2015 07:55 PM
J.B.Motorwerks2
Aug 10, 2013 05:29 PM
Tgang94
Oct 19, 2012 08:00 AM
campbmic
Mar 20, 2011 08:39 AM
ACCORD_1987
May 4, 2008 07:44 AM
