looking for fuel filter,pump,etc
Old Dec 19, 2005 | 12:43 PM
$krillah's Avatar
Default looking for fuel filter,pump,etc
hey, i am fairly new to the tuning game, so go easy on me, my 2000 ex has been making some funny noises, like it is being starved for fuel(or something), i think i might have a clogged filter, or water in the line. Like i said, i don't know much about engines, but love to learn, anyone know where that stuff is located
Old Dec 19, 2005 | 12:46 PM
Luserkid's Avatar
Default Re: looking for fuel filter,pump,etc ($krillah)
Take it to a mechanic and ask for a full tune up.
Old Dec 19, 2005 | 01:20 PM
transpar_nt's Avatar
You're fuel filter is in a 4x4" housing attached to the firewall more on the left side of the engine bay. There will be two lines going from it, one going to your fuel rail which holds the injectors.
The fuel pump is located under the carpet near the back in the center, covered by a metal dome.
Your pump is almost definitely fine, but your fuel filter could probably use changing. Also depending on which octane gas you've been using your injectors might have some buildup on/in them. If you say its "been making some funny noises" that could be almost anything. It most likely isn't being starved for fuel.
Old Dec 19, 2005 | 03:48 PM
_gurusan_'s Avatar
Default Re: looking for fuel filter,pump,etc (transpar_nt)
werd...but Octane has nothing to do with how clogged up the injectors would be
Old Dec 19, 2005 | 06:04 PM
$krillah's Avatar
Default Re: looking for fuel filter,pump,etc (_gurusan_)
to answer your question, i use 87 octane and the noise is a sputtering sound, but only in the low rev range
pjr710
Apr 3, 2010 05:59 PM
646EG
Jan 16, 2008 09:30 PM
garyc17
May 17, 2006 07:20 AM
crnimacak
Apr 21, 2006 10:11 PM
EVOCELICA
Oct 12, 2003 11:05 AM
