need help!!!!!
Old Dec 19, 2005 | 10:14 AM
sohc90rex's Avatar
Default need help!!!!!
car wont start it cranks but it doesnt start..... its like it is not getting spark it wants to start... d16a6 i/h/e
Old Dec 19, 2005 | 10:19 AM
downest's Avatar
Default Re: need help!!!!! (sohc90rex)
Is it not getting spark or you just think that's the problem? Check the T-stat ground, and if it is getting spark and not turning, check the main relay.
Cheeech's Avatar
Check the spark and fuel, if u have that, then your distributor might be bad.
Old Dec 19, 2005 | 10:23 AM
sohc90rex's Avatar
it jus cranks... its like it wants to start .... wen i was driving on the freeway the engine jus turned off. nd pulled over tryied to start it all i get is a crank then called a tow truck bring the car home...
Old Dec 19, 2005 | 10:24 AM
sohc90rex's Avatar
ecu no codes
Old Dec 19, 2005 | 12:00 PM
sohc90rex's Avatar
ne one else
Old Dec 19, 2005 | 03:12 PM
EF8-SiR's Avatar
check the distributor , remove the cap and check if the screw didn't came of the rotorif it did just get another screw
Old Dec 19, 2005 | 05:19 PM
sohc90rex's Avatar
checked everything... everything is fine distrubitor is new nd rotor.... nething else guys thanx for ideas
Old Dec 19, 2005 | 05:22 PM
C1CRX's Avatar
Traffic signal tech
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc90rex &raquo;</TD></TR><TR><TD CLASS="quote">it jus cranks... its like it wants to start .... wen i was driving on the freeway the engine jus turned off. nd pulled over tryied to start it all i get is a crank then called a tow truck bring the car home... </TD></TR></TABLE>
kinda sounds like a coil to me but u say your dizzy is fine ..does your fuel pump prime??
Old Dec 19, 2005 | 05:37 PM
Crx Jimmy's Avatar
Default Re: need help!!!!! (lvcrx)
i would say ignition coil or fuel pump broken or not working
Old Dec 19, 2005 | 05:42 PM
AychTwenee2's Avatar
I had a friends do that, and it was the ignitor in the dizzy. It happened about 3 times in that damn car. It's at the bottom part of the dizzy under the rotor. Check that bro
Old Dec 19, 2005 | 09:26 PM
sohc90rex's Avatar
fuel pump still good checked my igniton coil nd its good but i havent checked the igniter yet i kno its located in the bottom but how do u take it out....
Old Dec 20, 2005 | 03:07 AM
1QuikSOHCZC's Avatar
if u know any one else with a crx try ur distributor on theirs and theirs on ur car..make sure al the conections inside the dizy r on good
Old Dec 21, 2005 | 08:25 AM
sohc90rex's Avatar
Default Re: need help!!!!! (1QuikSOHC)
ne one else
Old Dec 21, 2005 | 06:42 PM
sohc90rex's Avatar
could it be my igniter
Old Dec 21, 2005 | 07:00 PM
C1CRX's Avatar
Traffic signal tech
does your tach ever bounce around while driving if so then yeah your ignitor is bad
Old Dec 21, 2005 | 09:20 PM
sohc90rex's Avatar
nope my rpm doesnt bounce around. so it could be the distributor....
pabstj
Sep 6, 2005 07:24 PM
amari
Mar 20, 2005 11:57 AM
contimheokho
16
Oct 26, 2004 07:34 PM
hurleyboarder21
Apr 12, 2004 07:22 PM
neof69
Jan 12, 2003 06:10 PM
