Clunking Noie when hitting the brake pedal???
Ok when you brake in my 93 Civic EX the driver side front brake makes a clunking noise. Just 1 thud and thats it. Brake pedal still feels good and car stops great. What could be the problem.
Oh yea it's non-ABS
Oh yea it's non-ABS
Could be a few different things pertaining to your suspension on that corner. I would first check to see if it is simply the pad rocking back and forth in the caliper. This happens sometimes when the little metal shims that go on either end of the pads fall out or were not installed properly.
Thanks I'll check to see if it's still there. I changed the pads about 6 months ago. It started to clunk maybe a month and a half ago maybe 2 months.
AndyD
Sep 30, 2010 05:25 PM
It's a 93, they should probably be replaced anyway.
