Hinges on my cargo cover
Old Dec 19, 2005 | 09:56 AM
Jesterian's Avatar
Default Hinges on my cargo cover
Alright, I got a cargo cover not too long ago and noticed that honda decided that fabric would be enough to use as a hinge to keep the whole thing together. I went to home depot and picked up a couple of 1.5" steel hinges to use to keep it together. Now I'm wondering what the best way might be to attach the hinges? They come with .5"(ish) screws to attach them, but the screws would go right through the cargo cover and come out the other side. That'd look sloppy and I don't want that. Anyone have any suggestions?
Old Dec 19, 2005 | 10:06 AM
1989CivicSi's Avatar
Default Re: Hinges on my cargo cover (Jesterian)
Epoxy + fiberglass
Old Dec 19, 2005 | 10:07 AM
Jesterian's Avatar
Default Re: Hinges on my cargo cover (1989CivicSi)
What's the fiberglass for?
Old Dec 19, 2005 | 11:11 AM
Targa250R's Avatar
be professional
Bolt + nut + washers instead of screws. Or you could try a pastic piano hinge instead of regular hinges - info on this option is here.
Old Dec 19, 2005 | 12:52 PM
rsca_crx's Avatar
Default Re: Hinges on my cargo cover (Targa250R)
black plastic piano hinge with black rivets
Old Dec 19, 2005 | 12:58 PM
Default Re: Hinges on my cargo cover (rsca_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jesterian &raquo;</TD></TR><TR><TD CLASS="quote">What's the fiberglass for?</TD></TR></TABLE>
The fiberglass is completely optional (for added strength over a greater surface area). If I was going to do the hinges though, this is how I'd do it:
1. Strip the carpet from the area in which you plan to glue the hinges or fiberglass (probably underside so it'll look clean).
2. Carefully epoxy the hinges in place taking care to ensure no epoxy gets in the way of the hinge...I'd use 5 minute so it lays up faster.
3. Lay the fiberglass over the flat surfaces of the hinge, and have it go over the edges about 1 inch (make sure the 1 inch area is clear of any carpet as well). Then when you have it positioned to where you'd like, mix some more 5 min. epoxy, and brush it over the fiberglass letting it soak in.
4. give it a quick sanding, and spray the fiberglass or hinge area black.
Done.
Total cost of parts: Not more than $20.00, and it'll last forever as long as you don't start using your cargo cover as a snowboard.
*Edit* Here is a ghetto 2 min. paint drawing of the above directions:
Good luck!
Old Dec 19, 2005 | 01:02 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsca_crx &raquo;</TD></TR><TR><TD CLASS="quote">black plastic piano hinge with black rivets</TD></TR></TABLE>
yeah, i got this stuff. comes black. worked great, looked great. except you need to glue the edge into it to make it stay even though its a nice tight fit, which i meant to do. then my cargo cover got stolen...(along with my tools!)
jbell
Honda S2000
16
Sep 18, 2008 06:26 PM
hometheaterman
Apr 26, 2008 07:29 PM
aarontrini85
Apr 23, 2007 05:14 PM
turboex
Jun 15, 2004 10:30 PM
dLo GSR-stolen-now-WRX
Nov 6, 2002 12:41 PM
