'98 with 3.0 VTEC Timing belt
Old Dec 19, 2005 | 05:53 AM
BobCT's Avatar
Default '98 with 3.0 VTEC Timing belt
How difficult is the timing belt job on these ? I've done DOHC V6 Toyota engines
but not Honda. I'm sure the concept is the same but it looks pretty tight.
A friend of mine has 150k on his original belt/pump. I assume that this is an
interferance engine ?
Old Dec 19, 2005 | 11:50 AM
achng123's Avatar
Default Re: '98 with 3.0 VTEC Timing belt (BobCT)
It is an interference engine. The handbook says to replace at 100,000 miles.
You are way overdue. I replaced mine at 90,000. Cost $500 including water pump
and all belts.
Old Dec 19, 2005 | 06:57 PM
Ross 2.0's Avatar
In a Junkyard near you.
You my friend are driving on borrowed time. And I mean that will all seriousness.
If that belt breaks you will be in a mother of a money pit.
Honda reccomends you change it at 105K miles. It's not so bad to do but if you have never worked on a Honda engine don't bothor.
Old Dec 20, 2005 | 08:55 AM
hondadude's Avatar
not too tough if you have the experience from doing a Yota, you'll have the T-belt turn more than you think when tensioning it. And I think on those engines the dip stick hole needs to be plugged when you change the water pump or you'll have a couple cups of coolant in the oil pan.
albee01
Nov 29, 2011 07:37 AM
turbotegra1834
Nov 5, 2011 07:35 PM
allen1466
Honda Civic (2001 - 2005)
Jul 10, 2008 06:36 PM
ildknyli
Apr 12, 2006 10:36 PM
weakGOODJunKieS.com
Apr 15, 2003 11:28 AM
