Transmission? or Idle?
Old Dec 18, 2005 | 05:33 PM
standbackimapro's Avatar
Default Transmission? or Idle?
if i stop at a red light or somthing, my car shakes, but if i put it into park or nuetral it dosnt shake as much
its a 1990 accord dx automatic
Old Dec 18, 2005 | 05:37 PM
P_Adams's Avatar
Default Re: Transmission? or Idle? (standbackimapro)
Bad rear Transmission (motor) Mount. That nasty unit in the supplied linked illustration:
Refer #4
http://www.hondaautomotivepart...MOUNT
P
Old Dec 18, 2005 | 10:24 PM
deserthonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">if i stop at a red light or somthing, my car shakes, but if i put it into park or nuetral it dosnt shake as much
its a 1990 accord dx automatic</TD></TR></TABLE>
i agree with P_ chk the motor mounts mostly rear and frt ,,if broken replace accordingly ,if mounts are ok,, make sure you get vacc at rear motor mount diaphram below 750 rpm ,, if u dont get vacc chk hose,+ solenoid operation..if u get vac. hook up a vacc pump to diaphram and make sure it holds vaccuum..if not replace rear mount
Old Dec 19, 2005 | 09:16 AM
hondadude's Avatar
http://members.troublecodes.ne...e.htm
Link shows rear motor mount operation ..also check the top of the front subframe'dogbone' mount, they go bad a lot as well; the 5speed 'dogbone' is the same size as the automatic type but has stiffer rubber in it. price is the same
Old Dec 19, 2005 | 11:13 AM
P_Adams's Avatar
An additional hint for ID'ing a bad Rear Engine Mount.
the Vibration when in Reverse will be far worst than in neutral or forward.
It will be bad enough to Rattle Teeth, Blur Vision, Shake parts from the car (particularly the front bumper) and cause women to take their children off the streets. Dogs will disappear, birds will fall silent and the local EMS office will raise the threat level to Orange!
Get it checked out before the Earth opens up
P
Old Dec 19, 2005 | 09:21 PM
tjohnson329's Avatar
Default Re: Transmission? or Idle? (P_Adams)
yes, definetly one of those motor mounts.
fever502
Jan 9, 2006 05:49 PM
G2_Fella
10
Jul 28, 2005 12:04 PM
y0whuddupb
Feb 24, 2004 01:30 AM
moreno
Jan 29, 2004 03:54 PM
