getting B16 to 200 hp all motor.
Old Dec 18, 2005 | 04:33 PM
solo303's Avatar
Default getting B16 to 200 hp all motor.
what's your recipe to get a b16 to 200 hp all motor, no turbo, and yet pass emission?
Old Dec 18, 2005 | 04:36 PM
I Have an STD's Avatar
wrenchin'
Default Re: getting B16 to 200 hp all motor. (solo303)
its not possible. u need to go bigger. ur gonna need a TON of compression, wild cams and race gas to do it. which wont pass emissions
sanimalp's Avatar
$cat /dev/urandom
but really, check out the na forum on honda-tech. i just saw a post about it yesterday, a guy dynoed his na b16 at 202 hp or something close. pass emmissions.. well i dont know but..
wait.. its stickied in the na forum.. its a video about your question.
https://honda-tech.com/zerothread?id=1319890
Old Dec 18, 2005 | 04:41 PM
89 pos's Avatar
Default Re: getting B16 to 200 hp all motor. (sanimalp)
i would not even pay 80 for sex and damn sure not a vid
Old Dec 18, 2005 | 07:08 PM
civickiller's Avatar
Default Re: getting B16 to 200 hp all motor. (89 pos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89 pos &raquo;</TD></TR><TR><TD CLASS="quote">i would not even pay 80 for sex and damn sure not a vid</TD></TR></TABLE>
thats because you dont have the love of th sport like some of us do
Old Dec 18, 2005 | 07:18 PM
Hamstr323's Avatar
even if you paid YOU STILL COULDN'T GET LAID
Old Dec 19, 2005 | 12:11 AM
ludesrv's Avatar
We got 187whp out of a B16A powered 91 Hatch Si.
What it had:
Skunk 2 stage 2 cams.
Skunk 2 valve/retainers/springs
P&P
CTR pistons, mugen head gasket 12:1 compression.
DC sport ITR headers, Skunk 2 92-95 exahust shortened to fit EF chassis.
new everything.
Chipped ECU.
Rev limiter at 9200rpm and motor makes power all the way to it.
92-96 Prelude injectors
Stock fuel pump
If he would spend another 500$ on better injectors and pump and up the compression ratio he might be able to with 200whp...but guess what, all that money and the car still can't hit 14.1 street tires on the 1/4 mile. Simply doesn't have the torque to launch out of the hole.
It got beaten by a 91 Si hatch with GSR motor, stock, with ITR intake manifold, AEM CAI, DC sport header and Skunk 2 92-95 exhaust cut to fit EF. It ran a 14.0.
Best times for both those cars where ran by the same driver on the same rims and tires...guess what, 1.6L built gets owned by 1.8L stock.
Go adleast 1.8L for a build.
EDIT: He passed etest on cheater stats. Retard the timing, lean fuel, put D16Z6 stock ecu in, stock header/cat for b16a and stock si exhaust. He was told NOT to go over 4000rpm on his way there and back. Running on 94 fuel with octane booster and had the motor nice and warm, barely passed . Honestly, get your car e-test BEFORE you put that motor in to pass then you have 2 years e-test free!
Old Dec 19, 2005 | 04:43 AM
Autoworks's Avatar
Default Re: (ludesrv)
Bolt ons and a "nasty tune"
Old Dec 19, 2005 | 04:49 AM
Autoworks's Avatar
ludesrv-are you still using OBD0? Asking because there are B16 CRX's here running 14.4-14.7 with less power and mods than you. You would probably pull more power and net better times with a different tune (OBD1+Hondata)
My 147whp would run all over a GSR swapped EM/EJ...different chassis, but they did make more whp.
I think Omni had the best recipe for the 200whp N/A B16
brjhnson
Honda Civic (2001 - 2005)
Feb 14, 2007 08:53 AM
civicsi0721
15
Aug 28, 2006 10:06 PM
cibrlx01
Feb 7, 2006 01:49 PM
C2Imports
38
Jun 6, 2005 11:57 AM
S@nt0s
24
Jul 9, 2003 10:20 AM
