ICM Igniton Control Module Bad?
Old Dec 18, 2005 | 02:57 PM
zCivic's Avatar
Default ICM Igniton Control Module Bad?
I've tested per helms and everything checks out. Just wondering if needs to be replaced because it does spark (very random though).... While cranking it will spark once then nothing. Crank again nothing. Swapped ECU's so thats not the problem. Just never knew the symtoms of one going bad.
Old Dec 18, 2005 | 04:42 PM
riceburnerryan's Avatar
is the ECU throwing any codes? check the connections once over, and if you can get a multimetere to see if there is any current to those wires, and if there is, then i would guess the ICM
Old Dec 19, 2005 | 04:29 AM
zCivic's Avatar
Default Re: (riceburnerryan)
No CEL's. I tested buy helms so already used a multimeter. So next step is relacing the ICM
gole
Honda CR-V & Element
Dec 22, 2014 04:56 PM
coltonbarrier
Dec 4, 2013 12:55 PM
dunked dc
May 16, 2010 08:31 AM
huge230
Oct 2, 2005 09:59 PM
Verdegsr
Dec 29, 2003 06:31 PM
