Car wont start.. No CEL
Old Dec 18, 2005 | 02:56 PM
Formula Racing's Avatar
Default Car wont start.. No CEL
Its a98 4cyl accord
I dont ever see the CEL and the car wont start. It spins fine, but wont fire.
What could it be?
Thanks
Old Dec 18, 2005 | 05:09 PM
P_Adams's Avatar
Default Re: Car wont start.. No CEL (Formula Racing)
We're going to take a trick from the 5th Gen guys and ask you to do something. It will help point in the right direction.
Take the plastic tube which runs from your air cleaner box and disconnect it from the throttle-body. Spray a two-three second burst of Carburetor Cleaner past the butterfly valve into the intake plenum.
Try starting the car.
If it starts and runs momentarily, suspect the main relay. It's responsible for operating the fuel pump and powering the ECM (Engine Control Module
P
Old Dec 18, 2005 | 06:56 PM
Ross 2.0's Avatar
In a Junkyard near you.
Or if your nervous about fire. Just turn the key to on and listen for a click in about 4-5 seconds. Check your fuses too (in all of the fuse boxes).
Old Dec 18, 2005 | 07:12 PM
all fuses ok.
Injectors dont appear to be firing. Fuel pressure is present.
Im stumped!
I tried the paperclick thing.. No CEL..
Old Dec 18, 2005 | 07:27 PM
P_Adams's Avatar
Default Re: (Formula Racing)
Could still be the main relay: no power to the ECM, no CEL (Check Engine Lamp), no Injector operation.
Just thinking out loud
P
Old Dec 18, 2005 | 07:28 PM
Ross 2.0's Avatar
main relay.. Do what P_Adams said then.
Also look for a flashing picture of a key while trying to start it.
Hondatechnoobi
May 1, 2015 08:02 PM
91ef_civic
Mar 11, 2011 08:39 AM
Ghost Civic
20
Aug 4, 2010 02:07 PM
illestrolla247
Apr 4, 2005 06:24 PM
