just installed a cai
Old Dec 18, 2005 | 10:49 AM
thelonerangers's Avatar
Default just installed a cai
when i was reading over the paper work at the bottom of the installation instructions it said to reflash the ecu to "learn" of the intake, disconnect the - lead on the battery. should i do this i would rather ask u guys than some stupid mass produced directions.
Old Dec 18, 2005 | 10:52 AM
92ehatch's Avatar
Default Re: just installed a cai (ian22)
you will probably get mixed answers on this, i say go ahead and do it leave it off for like 30 seconds and it will be cleared.
Old Dec 18, 2005 | 10:53 AM
Default Re: just installed a cai (93egsedan)
wat r the possible problems it can cause tho? cause it said do it at your own risk
Old Dec 18, 2005 | 10:54 AM
92ehatch's Avatar
resetting the ECU is like just unplugging a running computer.
it CAN hurt it, but not likely
Old Dec 18, 2005 | 11:05 AM
ekcivic9's Avatar
if your scared to reset your ecu. then leave your car on for 15 mins and let it idle... dont touch it. ecu will reset that way also.
Old Dec 18, 2005 | 11:30 AM
7808's Avatar
Default Re: (ekcivic9)
why dont you just do it
Old Dec 18, 2005 | 11:33 AM
anony95ex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ian22 &raquo;</TD></TR><TR><TD CLASS="quote">wat r the possible problems it can cause tho? cause it said do it at your own risk</TD></TR></TABLE>
It's not going to hurt anything. You have to disconnect the battery when you put a new battery in, or change a starter or alternator, right? It is going to reset the PCM, not a big deal, you'll be fine. If there's any codes or if the CEL is on, the codes will be erased and the light will be off until the computer finds the problem(s) again.
What damage can it do? The worst it can do is erase the preset stations in your radio and reset any clocks in the car, that's about it...minor inconvenience.
Now, what will it do for you? Probably nothing. It's highly unlikely that you'll gain any extra power at all by resetting the computer...not worth the hassle of resetting the clock(s) and radio stations IMO.
Old Dec 18, 2005 | 11:35 AM
Sleepy_Red_hatch's Avatar
Default Re: just installed a cai (anony95ex)
what do you think happens when you change your battery? you have to disconnect it. what about bringing it in for testing. disconnected. what about when you buy a swap, the ecu doesnt come with a battery pack.
Old Dec 18, 2005 | 11:37 AM
Default Re: just installed a cai (Sleepy_Red_hatch)
thanx for the answers, i didnt trust the directions.
Old Dec 18, 2005 | 05:39 PM
Ghetto Civic HX's Avatar
I love to drive
It probably says that just in case something random happens while you reset the ECU. That way you can't sue them.
Old Dec 18, 2005 | 05:44 PM
postman's Avatar
if you have an obd2 disc. battery will not reset ecu. you have keep alive memory. the reason why you even do it is to relearn the iac. just let it idle for a while
Old Dec 18, 2005 | 06:04 PM
Default Re: just installed a cai (postman)
how long should i let it idle?
Old Dec 19, 2005 | 05:11 PM
civ_tek's Avatar
Old Dec 19, 2005 | 05:36 PM
ekcivic9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">if your scared to reset your ecu. then leave your car on for 15 mins and let it idle... </TD></TR></TABLE>
Old Dec 19, 2005 | 06:09 PM
Royal_C!ty's Avatar
Default Re: just installed a cai (civ_tek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ_tek &raquo;</TD></TR><TR><TD CLASS="quote">if your scared to reset your ecu. then leave your car on for 15 mins and let it idle... dont touch it. ecu will reset that way also. </TD></TR></TABLE>
Damn i never knew that ... learn something new everyday
Old Dec 19, 2005 | 06:47 PM
preludepower's Avatar
Ok well...a couple things.
-No it will not hurt anything if you do this...like it's been posted earlier, worst it will do is reset your radio stations.
-resetting your ecu allows it to relearn fuel curves; this is why a cold air intake usually produces more hp. The IAT sensor tells the computer that the air is colder/more dense with oxygen, and in response, the computer can add more fuel.
P.S. *If you are working on/replacing your battery, you can avoid losing your radio presets and other settings by leaving the car running while you change the battery.*
mehheh1029
Jun 7, 2006 05:13 PM
A-busive
Aug 8, 2005 11:01 AM
eswaroop
Apr 8, 2004 03:37 PM
Champ R
May 23, 2003 07:01 AM
HoNdAeX11
Sep 14, 2001 07:55 PM
