My Setup and Dyno #'s
Old Dec 18, 2005 | 10:31 AM
DJsilkyjr's Avatar
Default My Setup and Dyno #'s
97 GSR Block w/ Type R Pistons
99 Type R Head milled 5th over
Type R intake Manifold
H22 Injectors
B16 Trans
Stage 2 Clutch w/flywheel
DC 4-2-1 Header
Str Fuel Rail
Tuned w/ Vafc II
Best Run- 177.11 whp
135.55 torque
Dyno'd on DynoJet
For anyone that wants to see a dyno graph, dident no how to load it on here, but can email if you'd like, is this about how much power i should be putting out?
Modified by DJsilkyjr at 7:43 PM 12/18/2005
Old Dec 18, 2005 | 12:15 PM
96dc2's Avatar
Default Re: My Setup and Dyno #'s (DJsilkyjr)
How did the A/F ratio look like? You can email me at vwjimagekru@hotmail.com and I'll host the pic for you.
Old Dec 18, 2005 | 09:41 PM
96dc2's Avatar
Default Re: My Setup and Dyno #'s (96dc2)
Here is your graph. Was there a torque graph also?
Old Dec 18, 2005 | 10:54 PM
Viorent Grip! EG's Avatar
your numbers to me seem kind of low.
upgrade your cams and get a better header and get retuned with a better tuning management system.
hopefully that will put you at 190+whp
Old Dec 19, 2005 | 12:03 AM
fmrprojects's Avatar
Default Re: My Setup and Dyno #'s (Viorent Grip! EG)
theres more in that baby
Old Dec 19, 2005 | 12:35 AM
Downey's Avatar
which header and cams are you using?
Old Dec 19, 2005 | 08:17 AM
Default Re: My Setup and Dyno #'s (Downey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">which header and cams are you using?</TD></TR></TABLE>
DC 4-2-1 and stock type R cams i'm guessing...
doesnt seem like the cams are tuned either
Old Dec 19, 2005 | 02:14 PM
Damon B.'s Avatar
those numbers seem fine to me, it looks like he just turned his gsr motor into a basically stock type R motor...
Old Dec 19, 2005 | 02:39 PM
DJsilkyjr's Avatar
Default Re: My Setup and Dyno #'s (CleanSi or BallinG35)
Im using stock type r pistons and dc 4-2-1 header, from what i hear from shops around here, with just a vafc, 177 is about what i should be getting, besides switching over to Hondata and or tearing my motor apart, is their anything else i could do bolt on wise to gain more power?
Old Dec 19, 2005 | 06:29 PM
polynesia's Avatar
What exhaust setup are you running...?
I'd swap to a 4-1 setup with 2.5 collector, run a 2.5 mandrel bent system, either custom or off the shelf... depending on your budget...?
Old Dec 19, 2005 | 07:08 PM
DJsilkyjr's Avatar
Default Re: My Setup and Dyno #'s (polynesia)
greddy sp2 with 14" resinator, no cat
Old Dec 19, 2005 | 07:19 PM
young noob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJsilkyjr &raquo;</TD></TR><TR><TD CLASS="quote">97 GSR Block w/ Type R Pistons
H22 Injectors
B16 Trans
DC 4-2-1 Header
Str Fuel Rail
Tuned w/ Vafc II
135.55 torque
Dyno'd on DynoJet
Modified by DJsilkyjr at 7:43 PM 12/18/2005</TD></TR></TABLE>
an intake?????
Old Dec 19, 2005 | 07:30 PM
DJsilkyjr's Avatar
yea i got an intake, im about to go pick up a 65mm throttle body, might gain something from that im assuming...
Old Dec 19, 2005 | 07:45 PM
young noob's Avatar
Default Re: (DJsilkyjr)
get an itr 3inch cai, aem, been proven time and time again
Old Dec 19, 2005 | 07:49 PM
Downey's Avatar
judging by the dyno chart, it looks like hes got a cold air already. theres the 4000-4500 AEM "hump".
i made 180whp with a similar set (jdm 4-1, high flow cat, hondata)
i changed to rc 440's, swapped out my jdm 4-1 for a Mugen 4-1 and changed my rsr muffler to a Magnaflow, but kept the RSR piping.
i gained power everywhere.. from idle all the way to 8400. i gained as much as 10whp in certain places. peak numbers jumped to 186whp.
Old Dec 20, 2005 | 09:22 AM
DJsilkyjr's Avatar
After i install the 65mm throttle body, i was thinking about changing out headers but from what i hear, the header i have now DC 4-2-1 is a decent header, any other headers u guys recommend that isnt 1000$ plus?
Old Dec 20, 2005 | 09:55 AM
OH_SNAP10k_SHIFT!'s Avatar
http://www.tunerzine.com/news/....html
see if that works. there was another one on here too. cant find it tho. it was recent(1 week) try changing ur exhaust also to a less restrictive one.. which means louder for the most part. then tune it again, if u cange ur header. some header like to run lean.
Old Dec 20, 2005 | 09:57 AM
Uncle Willie's Avatar
Profab, edelbrock, smsp, just to name a few. There is a million threads out there now that are all about headers.
Also you could try searching the classifieds and u might be able to find a good deal on an rmf, or hytech.
B18C1_POWER
30
May 2, 2008 12:32 PM
tech0937
22
Mar 27, 2008 09:03 PM
6SPD_EK
31
Oct 17, 2006 12:07 PM
DJsilkyjr
Dec 20, 2005 09:27 AM
athoughts
Feb 6, 2005 04:23 PM
