HELP!!! problem with starter turning but not starting my car
Old Dec 18, 2005 | 10:04 AM
classciv's Avatar
Default HELP!!! problem with starter turning but not starting my car
ok my crx has been sitting for about a month now, because of the winter season. i go out today to move it and the starter turns the engine over fine once. the next time to go to start it i can hear the starter turning but it is not turning the engine over, it just sounds like the starter is running but the gears arnt catching. is it possible for the starter teeth to grind off?
Old Dec 18, 2005 | 10:09 AM
si0385.'s Avatar
Default Re: HELP!!! problem with starter turning but not starting my car (classciv)
i doubt the teath are ground off however anything is possible with the winters up there ... hopefully there not ground off the flywheel... it most likeley is the shaft on the starter stuck and spinning but not moving out to grab the flywheel... pull it and check the teeth
Old Dec 18, 2005 | 10:13 AM
tyro's Avatar
Default Re: HELP!!! problem with starter turning but not starting my car (jaydeum4lyfe)
Check your 'overrunning clutch' in your starter, part 5:
Part is pricey..I'll suggest pick n pull for a new starter..
Old Dec 18, 2005 | 10:39 AM
classciv's Avatar
Default Re: HELP!!! problem with starter turning but not starting my car (tyro)
damn that sucks, it is cold down here, do you think maybe a heatgun on it might warm it up? and if i am heading to the junk yard, are all b series starters the same, i am running a b20z with a b16 tranny
Old Dec 18, 2005 | 10:41 AM
bonestock91's Avatar
check your dizzy. mine grenaded 2 weeks ago.
Old Dec 18, 2005 | 11:27 AM
classciv's Avatar
Default Re: (bonestock91)
put the heat gun to it for about 3 min and it started right up, thanks for the info guys
Old Dec 18, 2005 | 11:40 AM
tyro's Avatar
Default Re: (classciv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by classciv &raquo;</TD></TR><TR><TD CLASS="quote">put the heat gun to it for about 3 min and it started right up, thanks for the info guys</TD></TR></TABLE>
You heated up the starter and it was happy? Cool!
Old Dec 18, 2005 | 11:53 AM
classciv's Avatar
Default Re: (tyro)
haha yeah it chugged and gurgled for a little bit but then it turned over and started like a champ. it will be in my aunts (heated garage) till spring
dmanfree
Jun 21, 2013 12:38 PM
h22a_black
Feb 13, 2008 06:12 AM
383chevy
Jan 25, 2007 07:58 PM
RiCE On IcE 2
Apr 25, 2005 10:17 AM
HXvtec
Nov 6, 2004 02:15 PM
