Misc. CRX Questions
Here's the situation:
I bought an 88 CRX HF shell a while ago. The plan was to throw in a d15 from a 92 Civic that I picked up for $100 just to get it to run. So I picked up some parts I was told to get, and now there's a giant clusterf*ck as far as what I should do, so I'm turning to you guys for help and/or suggestions/comments. Here's my "parts" list:
-88 CRX HF Shell
-92 Civic DX d15b7 Motor/Transmission
-89 Civic Misc. Engine Parts (distributor, sensors, fuel injectors, etc.)
-91 CRX Si Transmission
-p28 ECU
-pm6 ECU
-92 Civic DX Wiring Harness
-91 CRX Si Wiring Harness
-91 CRX Si Fuel Injector Resistor Box
So here's my problem, I don't know where to go from here. The DX motor and Si Tranny is what I'm wanting to use, just because they're already assembled, it's more-so a question about the wiring.
Should I go OBD0 or OBD1? If I go OBD0, is there a way I can use OBD1 injectors, or rather, what is my best bet with what I've got?
-88 CRX HF Shell
-p28 ECU
-pm6 ECU
The 88 shell didn't come with the wiring harness, just the shell. I take it from your post then, that I should stick to OBD0. I've got a local guy here putting the wiring harness together. Looks like the only thing left would be to get Si injectors and be good. Would there be a way to use the injectors from the 92 Civic with/without a resistor box?
JUN.
Mar 26, 2006 12:42 AM
prjctCIVIC
Jun 27, 2005 06:30 PM
