installing itr final drive in 99-00 civic si... need to use itr ring gear and pinion?
Old Dec 18, 2005 | 09:19 AM
Black R's Avatar
25 Year Member
Default installing itr final drive in 99-00 civic si... need to use itr ring gear and pinion?
or just ring gear?
Old Dec 18, 2005 | 09:29 AM
RacerXI's Avatar
Default Re: installing itr final drive in 99-00 civic si... need to use itr ring gear and pinion? (Black R)
Thx Kenny. Long story short, I installed an itr lsd w/ ring gear into my 00 Si S4C tranny. With the casing off, you can spin the diff. & misc. gears with your hand, but when I had the car on the ground with the axles in yesterday the car wouldn't roll farther than 6 inches. I checked to make sure the car wasn't in gear and everything I could think of. Now I'm sitting with the top half of the casing off and it all spins which really stumps me. Either a) i'm using the wrong parts b) I goofed shimming the diff c) other....
HELP!!!
Old Dec 18, 2005 | 12:51 PM
six_speed's Avatar
you'll need the ring gear + the accompanying input shaft/new bearings
Old Dec 18, 2005 | 01:32 PM
RacerXI's Avatar
Default Re: (six_speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by six_speed &raquo;</TD></TR><TR><TD CLASS="quote">you'll need the ring gear + the accompanying input shaft/new bearings</TD></TR></TABLE>Can someone confirm this? Before I take the tranny apart again.
Old Dec 18, 2005 | 03:00 PM
Aquafina's Avatar
Default Re: (RacerXI)
AFAIK you always use the matching ring gear and countershaft.
Old Dec 19, 2005 | 05:37 AM
Rene M's Avatar
Default Re: (Aquafina)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">AFAIK you always use the matching ring gear and countershaft.</TD></TR></TABLE>
All ways use a matched set never mix and match.. things go boom..
orioncivic
Transmission & Drivetrain
Aug 31, 2008 07:17 AM
Targa4Life
Oct 17, 2006 11:53 PM
I B BANGGIN
Sep 7, 2006 04:45 PM
gilou bilou
Nov 28, 2005 03:42 AM
skafia
Apr 21, 2003 08:06 AM
