cam positioning sensor code 6?
Old Dec 18, 2005 | 09:13 AM
rc90hatch's Avatar
Default cam positioning sensor code 6?
why is my computer throwing this code?
Old Dec 18, 2005 | 09:20 AM
Mach69's Avatar
Default Re: cam positioning sensor code 6? (rc90hatch)
um... code 6= coolant temperature.
here go to this h-t site: https://honda-tech.com/zerothread?id=468260
Old Dec 18, 2005 | 09:34 AM
rc90hatch's Avatar
Default Re: cam positioning sensor code 6? (Mach69)
thanks for the links to thos4e diagrams for codes, really appreciated..rc
Old Dec 18, 2005 | 09:48 AM
rc90hatch's Avatar
would coolant temp. code cause the car not to start?
Old Dec 18, 2005 | 09:53 AM
C1CRX's Avatar
Traffic signal tech
when my ECT was broke my car wouldnt start up right away when it had been sitting for a long time but would start up fine once it was warmed up ......what kind of symptoms are u having
Old Dec 18, 2005 | 09:56 AM
rc90hatch's Avatar
Default Re: cam positioning sensor code 6? (lvcrx)
well the car was sitting for 3 months with the battery disconnected, it still has power but when i crank the motor itll get stuck almost like theres not enough juice to the starter to start the car and the interior lights will shut off for 30 secs, its weird and its pissing me off, when it actually cranks itll start but very very low idle and chopy and will stall, help bro im loosing my mind cause i know its osmething stupid that can be fixed very easily
Old Dec 18, 2005 | 10:21 AM
C1CRX's Avatar
Traffic signal tech
check the wiring on the ECT sensor and check the grounds on your thermostat housing make sure its on there nice and tight
Old Dec 18, 2005 | 02:19 PM
rc90hatch's Avatar
alright ill check that, but would it make my car not start?
Old Dec 18, 2005 | 04:12 PM
C1CRX's Avatar
Traffic signal tech
it could if your thermostat housing ground isint put on
Old Dec 19, 2005 | 02:19 AM
VegaS10's Avatar
Could be low voltage in the car. Let it sit on a battery charger for a little while. 3 months is a long time for a battery...
Old Dec 19, 2005 | 03:19 AM
rc90hatch's Avatar
Default Re: (VegaS10)
word, thats what i was going to do today, i think thats the problem plus i need to re-wire the ground and coolanyt temp. sensor plug and plug that **** in, then i should be throwing any codes and the car should start right up.
Old Dec 27, 2005 | 11:05 PM
lsveg's Avatar
would the ect make vtec not kick in? i just swaped a b16a into a crx si and the vtec isn't kicking in. i'm going to check the sensor tomorrow. thanks guys,
calcamaro
Jul 15, 2018 01:56 PM
amanda-justine
May 13, 2013 08:22 PM
94c1v1cex
May 18, 2009 05:07 PM
crx_91si
Jan 22, 2002 05:06 PM
