Removing Rear Seat on '89 Civic Si
They seem to have a center pivot pin and then the pins into the side of the interior panels, maybe I'm missing something. I'll give it a go again. Thanks, Dave.
On the window sides of the seats there are spacers that you must pull out to allow the seat to slide back and forth. So once you pull that spacer out you can slide the seat all the way to one side and slide it off
pull up the rear trunk carpet until you can see the back of the seats, there are some 10mm bolts you need to remove to get the passenger side off and then the driver side has a bolt in-line with the pivot and a couple more on the side w/ a bracket
Got'em, thanks for the help! The spacers did the trick for the fold-downs. There was a 10mm bolt holding the back of the bottom seat cushion as well--with this removed the lower popped right out. Regards to all, Dave.
sunsetway
Jun 7, 2003 11:19 AM
