I know this should be in the tech forum but.......
Those guys that go in there don't seem to want to answer anyone. And if they do it is do a search. I would like to know what the width of the wheel base is. From side to side. And also would it be possible to put say; a S2000 type V rack and pinion in a 92 Si? So the Si would have a super fast steering rack and pinion? What do you guys think?
The track width should be available in the specs on honda's website.
As for the steering rack.... I highly doubt you'd be able to get it in a civic without major fabrication.
-Mike
-Mike
Ok I found it. The width of the cars suspension is 68.9 thanks stock S2000 turning radius lock to lock is 2.4 The type V from Japan is 1.7 lock to lock. Thanks
