scratching noise when driving
Old Dec 17, 2005 | 09:25 PM
okaycivic99's Avatar
Default scratching noise when driving
There is a scratching noise of some sort when I'm driving my civic. It sounds like its coming from the front passenger side. I'm thinking it there is a problem with either the axle.
Can anybody give me an opinion of what the problem is and how to possibly fix it without going to a mechanic???
Old Dec 17, 2005 | 09:40 PM
.Grimace's Avatar
footwork mastery
Default Re: scratching noise when driving (okaycivic99)
seems like a "scratching noise" could be any number of things. a little more detail or what happened that started it would help
Old Dec 18, 2005 | 10:36 AM
I think I found the problem. There is a metal plate right behind the brake rotor. The plate is aligned against the rotor with a margin of about 2mm. Somehow the bottom part of the plate looks distorted and may possibly scratching against the rotor. Let me check this out and see if it works.
Old Dec 18, 2005 | 10:41 AM
SkoundrelUSA's Avatar
cute little bastard
The dust cover thing on the brakes?
Old Dec 18, 2005 | 12:56 PM
ShadyBAB's Avatar
Yeah had this problem too, all you gotta do is bend it out of the way of the rotor. BTW don't try to bend it right after you drove it, that **** will be hot! I learned the hard way
Old Dec 18, 2005 | 01:12 PM
1995Ex_Sedan's Avatar
I had a rock stuck between the two once. Freaking horrid sound. I thought something really bad happened. Took the wheel off and there was a pebble between em.
tercelrcr
18
Oct 31, 2014 05:27 AM
Griff911
Honda Civic (2001 - 2005)
Sep 2, 2008 11:42 AM
thavarin
Jul 2, 2007 02:55 PM
BlueIntegraBoy
Aug 19, 2005 03:46 PM
NWPNOMORE
Jun 20, 2002 10:22 PM
