maintenance need....
Old Dec 17, 2005 | 07:32 PM
Linh.'s Avatar
Default maintenance need....
My dads 96 honda accord maintenance light has turned to red. Not really sure what i am suppose to change like oil, coolant flush, timing belt, water pump etc. The car has 110xxx miles on it. What should i do?
Old Dec 17, 2005 | 07:43 PM
deserthonda's Avatar
Default Re: maintenance need.... (shooitslinh)
when was last time thr service was done?? 90K ? 105 k ?? is it a 4 cyl or v6 ?
if it has been at least 30k... replace oil, tranny fluid.if AT use Honda ATF-Z1 ,, if manual use 10w30 motor oil, air filter, brake fluid flush,use dot 3 or dot 4 .. plugs unless they are platinum ..then you should replace every 60k,, fuel filter every 30k, rotate tires every 7.5k, coolant every 30k, has timing belt been done?? if not DO it ASAP ,,
Old Dec 17, 2005 | 07:46 PM
BLKFLSH's Avatar
Read the owner's manual to find out what to do, and how to reset the light. I use the severe driving conditions list. Most people should.
Old Dec 17, 2005 | 09:30 PM
Linh.'s Avatar
Default Re: maintenance need.... (BLKFLSH)
it was done at 90k I believe I'll have to reread the manual cause I didn't see how to reset the light.
Old Dec 17, 2005 | 10:02 PM
flight50's Avatar
to reset just use the end of a key or small pointed object push in the little thinga ma jiggy on the bottom left hand side of your cluster gauges. it should be near were your rpm hand is.
kroze
Jul 10, 2005 10:08 AM
froger
Jun 3, 2005 08:58 PM
newhondaowner29
Aug 30, 2004 09:33 AM
illi Adik
Oct 24, 2002 11:39 PM
KooK
Jul 30, 2002 05:13 PM
