No power to the ECU
Old Dec 17, 2005 | 07:20 PM
TBoDelSol's Avatar
Default No power to the ECU
ok i tested everything and have no Power to the ECU. so what could it be. i have not check the wiring Harness or the ECU pins. but igntion system and alternator have power getting to it just let me know what you think
Old Dec 17, 2005 | 08:06 PM
postman's Avatar
Default Re: No power to the ECU (TBoDelSol)
ecu back up fuse
Old Dec 17, 2005 | 08:17 PM
CALIdelsolSIR's Avatar
Default Re: No power to the ECU (postman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by postman &raquo;</TD></TR><TR><TD CLASS="quote">ecu back up fuse</TD></TR></TABLE>
werd
Old Dec 17, 2005 | 08:18 PM
Sleepy_Red_hatch's Avatar
Default Re: No power to the ECU (CALIdelsolSIR)
fuse. in your engine bay fusebox i think its a 10amp?
Old Dec 17, 2005 | 09:13 PM
Relic1's Avatar
If your ECU does not have power at all (like you mentioned) then replace the 15 amp fuse in the underdash fuse box, it should be the one furthest from the blinker relay.
If that's not the problem it could be your main relay.
If it simply does not store the CEL or resets every time you turn off the key, then replace the backup fuse (7.5A) in the underhood fuse box.
that is of course assuming that you have an OBD1 DelSol... because you didn't leave a clue as to which car you have other than your ID....
Old Dec 17, 2005 | 10:40 PM
TBoDelSol's Avatar
Default Re: (Relic1)
sorry yes its a OBD1 93 Del Soli replace the whole fuse box in side the car i will look at the fuses in the engine bay tommrow thank you
Old Dec 20, 2005 | 04:26 PM
TBoDelSol's Avatar
Default Re: (TBoDelSol)
ok update checked all fuses they are good and checked main relay its good also im still confused
Old Dec 20, 2005 | 04:43 PM
h23civic's Avatar
go ahead and check your connectors going to your ecu and the pins. just make sure you don't use a test light on the pins. check the ecu grounds on the thermostat housing. if the grounds are disconnected or corroded really bad this could be your problem. good luck with it.
roseda91
Aug 12, 2007 01:25 PM
Carbcivic
15
Oct 16, 2005 06:28 AM
terribl3jon
Aug 26, 2004 12:23 PM
chuckd05
Nov 6, 2001 08:13 AM
