reverse lights are not coming on ....any thoughts?
bulbs are good. eg has JDM tail lights but that should not matter. anyone have any ideas? wires look good. motor swap , maybe something not hooked up from that?
i had same prob... one of the connectors by the spare tire area under the hatch had come lose.. all i did was cut the wire on both sides of the connector and attached them together... and now they work.. if i had a pic of where it is i would post it... just follow the wires from the hatch to the back panel just above the spare tire area... check there.. all i did with mine was use a test light.. then i wiggled the wires and they worked.. so i had to connect them
You said your car has a motor swap right?
Was your car an automatic before the swap? If so, there is a good chance the reverse light is not connected at all.
If you car was an automatic, then there would be a plug just chillin under the radio area...
You'll have to find out which pins on that plug are for the reverse lights, and run two wires to your reverse plug on your tranny.
Luserkid included how to do this in his 'auto to manual' write-up
https://honda-tech.com/zerothread?id=1337459
Yeah...you need to figure that out.
All you need to do is look under your radio (which might mean removing your lower console pieces), and look for this plug:
It's the big plug in the center. It plugs into the automatic shift unit, so that the computer will know when the car is in P, R, D, etc...
i don't mean to jack this thread but i am having the same prob since i put in my barnd new itr trans. the switch is new and i am getting power everywhere but to the lights themselves. and the bad part is my car is due for inspection next month... any ideas?
Canadian_EF
17
Jan 9, 2017 06:02 PM
esp4life
May 9, 2005 08:38 AM
CHONCH
May 30, 2002 05:58 PM
