converting
i have a 89crx si and planing to put an 96 ls/vtec engine into it do u thing it would be better to convert the car to obdII so that the engine would plug in. then convert to a obdI ecu or just stick with an odbII ecu and how would i go about doing either one
thanks for the help
Modified by ucc civic at 2:29 PM 12/17/2005
thanks for the help
OBD1 is best.. as mentioned..
You will use your stock vehicle harness, you will NOT change your engine harness.
You will however, change plugs, and extend certain wires.
http://rywire.com/store/produc...id=71
We try to make it as simple as possible. If you choose the Optional Modification Option, or stick with OBD0 Injectors, it will be a plug and play item.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">OBD2 converted to OBD1, OBD1 is da bomb for tuning.</TD></TR></TABLE>
DO NOT CHANGE ANYTHING TO OBD2.
Your distributor can be OBD2 and function with a OBD1 ECU just fine.
one last question can rywire do this and make it plug and play if so how much and what ecu do i need for it the Engine is a 96 ls and im converting it to vtec
thanks for all the help its much Appreciated
Chop the obd1 plugs with some wires out of a car in the junkyard, and find a burnt up obd2 ecu (I could get you one) and then take the plugs off there. Then solder all the corresponding wires together and you'll have a plug and play harness. Search around, there are plenty of pinouts and diys for that kinda stuff.
JCracer723
10
Jan 17, 2005 06:24 PM
