Honda S2000 Honda S2000
S2k Jack points - quick answer
Old Dec 17, 2005 | 11:48 AM
dtchmstr's Avatar
Default S2k Jack points - quick answer
So I need to jack up one side of my s2k and put it on jack stands. I don't have an owners manual. I can clearly tell where the back jack position is on the rear side. In the front side though, it looks like there are two places where it can be jacked, one right in front of the other. Are these both appropriate places to jack up the car? Do I have to jack the car from the front center jack point to be able to use a jack stand on the rocker panel?
Thanks
Old Dec 17, 2005 | 11:10 PM
Francesco's Avatar
Default Re: S2k Jack points - quick answer (dtchmstr)
use the central jack points...
oil pan and the rear diff...just be very careful...
if you need to set jackstands under the car, their are slots in the side frame beams for them to align with...
the owners manual shows this also...
Old Dec 17, 2005 | 11:25 PM
MAD ITR 55's Avatar
Default Re: S2k Jack points - quick answer (Francesco)
There is a jack point in the front. I would use that and not the oil pan.
Modified by MAD ITR 55 at 12:39 AM 12/19/2005
Old Dec 18, 2005 | 12:47 AM
Y's Avatar
Y
he doesnt have an owners manual
int96gsr
Apr 29, 2009 09:24 PM
crazyguy
18
Aug 1, 2008 04:46 PM
Balls
Jan 20, 2002 07:59 PM
SuperR
Dec 31, 2001 08:20 PM
