transmission swap
Old Dec 17, 2005 | 10:24 AM
98 widebody civic's Avatar
Default transmission swap
switching a 98 civic coupe from a automatic to five speed everything mechanical finished but
car will not turn over all lights and everything else works anyone have any solutions
Old Dec 17, 2005 | 10:27 AM
JDM-EJ1's Avatar
Default Re: transmission swap (98 widebody civic)
Check all your grounds? Is your starter installed correctly?
Old Dec 17, 2005 | 11:06 AM
hatchi's Avatar
is it cranking?? double check wiring etc
Old Dec 17, 2005 | 11:28 AM
Crazydave's Avatar
Default Re: transmission swap (hatchi)
Make sure you have the tranny ground strap from the tranny to the chassis connected well
Old Dec 17, 2005 | 12:19 PM
K20Ej1's Avatar
def. check ground
Old Dec 17, 2005 | 01:00 PM
sicones's Avatar
Default Re: (SPOONedEJ1)
did you do the wiring correctly in the center console to set the car to neutral, so the starter will crank, also you don’t need to wire it in park to pull the key, there is a very small 2 pin connector under the key cylinder in the steering column pull that out, the plus to this is that the lights on the dash will not light for the automatic stuff
92eg6_pino
Oct 9, 2010 04:56 PM
elnoyl
Apr 19, 2010 08:34 AM
hondatechguy25
Mar 11, 2007 04:51 AM
.Grimace
28
Jan 12, 2007 11:30 AM
Mackenzie
18
Oct 26, 2004 04:36 PM
