got a b16a2 from hmotors and the map sensor isnt on the tb
Old Dec 17, 2005 | 10:11 AM
gotboostedvr6's Avatar
Default got a b16a2 from hmotors and the map sensor isnt on the tb
motor in question is a b16a2 map is on tb
serial code starts with 12xxx....
it has an oil cooler before filter
oil bar above cam has duel raised edges along the center
iat sensor is on the runner on the im
rhd harness
i dont know if this matters but i didnt look if it had a knock sensor
motor is not obd2 no crank sensor
I removed the RHD harness last night all hardware that locks it in place including plastic zip ties that snap in to metal holders with 10 mm bolts ect were intact and never removed and the plastic clips some broke when I removed them. they were never removed in the first place im under the impression that its a virgin motor maybe a ukdm motor. I did a compression test and all #'S were very high :
225 220 230 217 dry
235 232 235 230 wet with light wd 40 spray
the head gasket is 3 layer and usdm b16 motors usually dont have compression that high ...disregard this if its irrelevant but its info i thought id give
also the oil filter was made by Vic which is a jap filter not to say you cant get them here but ive never seen them
so what's the verdict
http://www.superhonda.com/tech....html
B16A2 Honda Civic Si 1999-2000
B16A2 Honda Civic SiRII (JDM) 1992-1995
B16A2 Honda Del Sol (JDM) 1993-1995
Modified by gotboostedvr6 at 3:12 PM 12/22/2005
Old Dec 17, 2005 | 10:13 AM
Slopoke's Avatar
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (gotboostedvr6)
Yeps sounds like its from a DA.
I recently put the same motor into a EG that already had an LS swap in.
Just so you know, you'll need to swap out the timing belt mount(the one bolted to the block) for the mount from '94-up b series, in order to put it into your EG or EK.
Modified by Slopoke at 11:26 AM 12/17/2005
Old Dec 17, 2005 | 10:14 AM
dohcVTECeg2's Avatar
you got a B16a2?? if thats the stamp on the block you have a 99-00 Si coupe motor not a JDM XSi motor
Old Dec 17, 2005 | 10:16 AM
eg360B's Avatar
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">you got a B16a2?? if thats the stamp on the block you have a 99-00 Si coupe motor not a JDM XSi motor</TD></TR></TABLE>
yea or they just gave him a old *** head on the Si Block.. damn.. well if he says its obd1 then it wouldnt be a Si motor..
Old Dec 17, 2005 | 10:18 AM
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (Byrd Gang 021)
delsols came in obd2 also
so it has to be a xsi motor they are obd1 even if its 92?
Old Dec 17, 2005 | 10:26 AM
EJ8VTEC's Avatar
Mr. Indecisive
f u c k i n call up steve, u paid an extra 400+ for obd2, dont just accept it!!!!!!
Old Dec 17, 2005 | 10:31 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 &raquo;</TD></TR><TR><TD CLASS="quote">delsols came in obd2 also
so it has to be a xsi motor they are obd1 even if its 92? </TD></TR></TABLE>
Yes the '92 xsi motor is obd1.
What year civic is this going into?
Old Dec 17, 2005 | 10:38 AM
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (Slopoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8VTEC &raquo;</TD></TR><TR><TD CLASS="quote">f u c k i n call up steve, u paid an extra 400+ for obd2, dont just accept it!!!!!!</TD></TR></TABLE>
call hmotors if u got it from them. dont ask people on here to tell what motor it is. your the one in front of it. call steve and tell him your dilemma.
Old Dec 17, 2005 | 11:31 AM
damnraz's Avatar
I have a jdm b16a sir2, head stamp is 91 and is available in the 91-95 honda civics in japan, how do I know? because I bought an eg6 front clip and pulled the motor out, it's definately out of an eg and I used my stock map which was located on the firewall to plug into the TB before I swapped to an itr im/tb.
Old Dec 17, 2005 | 11:32 AM
damnraz's Avatar
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (damnraz)
oh yea, it is obd1
Old Dec 17, 2005 | 11:48 AM
Nuke209's Avatar
same here
Old Dec 19, 2005 | 07:05 AM
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (Nuke209)
he took care of me ty guys for the help
btw what car did a b16a2 come out of if is stamped 94 and map is on tb
ill chk if it has a knock sensor tonight
Old Dec 19, 2005 | 08:04 AM
EJ8VTEC's Avatar
Mr. Indecisive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gotboostedvr6 &raquo;</TD></TR><TR><TD CLASS="quote">he took care of me ty guys for the help
ill chk if it has a knock sensor tonight </TD></TR></TABLE>
del sol
Old Dec 19, 2005 | 08:22 AM
TurboEM1's Avatar
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (EJ8VTEC)
del sol</TD></TR></TABLE>
no
del sol had a b16a3
99-00 civic si had a b16a2
Old Dec 19, 2005 | 08:27 AM
91tegrals's Avatar
so did he take care of all this or was it not the wrong motor
Old Dec 19, 2005 | 08:57 AM
obd2 delsols had the b16a2 but the head stamp says 94 so it cant be
Old Dec 19, 2005 | 08:58 AM
I was taken care of and the replacement was worth my while ty for inquiring tho
Old Dec 19, 2005 | 10:04 AM
EJ8VTEC's Avatar
Mr. Indecisive
Default Re: got a b16a2 from hmotors and the map sensor isnt on the tb (TurboEM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
no
del sol had a b16a3
99-00 civic si had a b16a2</TD></TR></TABLE>
ur right, i was lookin that he said the head said 94 so...
Old Dec 19, 2005 | 10:08 AM
NJcoupe's Avatar
There was no OBD2 B16a2 Del sol In the States, and In Japan It would just be a B16A.
Old Dec 19, 2005 | 10:13 AM
vancoland's Avatar
omg...all these people have replies and everyone still deciding whether this is a jdm motor??...There is no b16a2 jdm motor...its a USDM if its stamp b16a2
Old Dec 19, 2005 | 12:01 PM
Default Re: (vancoland)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vancoland &raquo;</TD></TR><TR><TD CLASS="quote">omg...all these people have replies and everyone still deciding whether this is a jdm motor??...There is no b16a2 jdm motor...its a USDM if its stamp b16a2</TD></TR></TABLE>
where do you get this info from show me ?
and <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHDej2. &raquo;</TD></TR><TR><TD CLASS="quote">There was no OBD2 B16a2 Del sol In the States, and In Japan It would just be a B16A.</TD></TR></TABLE>
since when where there no b16a2 delsols in the states ive seen a few myself
Old Dec 19, 2005 | 12:17 PM
nsxmatt's Avatar
There are obd2 del sols. They were from 96-97 and the motor is the same code as the 99-00 SI.
The JDM B16 with a 91 head stamp is out of a 92 car which does not have a TB mounted map. Both of my B16's came this way and both were obd-1 hydro JDM B16's.
Old Dec 19, 2005 | 12:25 PM
Default Re: (nsxmatt)
ty sir for clearing it up
but i just got a jdm b16a2 with head code stamped 94 and its an obd1 motor with map on tb it has an jdm wire harness im wondering what car it came from
Old Dec 19, 2005 | 12:30 PM
Default Re: (gotboostedvr6)
there is no such thing as a "JDM B16a2" the a2 is the 96-97 del sol vtec and the 99-00 civic si coupe. just like the b16a3 is from the 93-95 del sol.
your an idiot. research your **** before you reply on here
Old Dec 19, 2005 | 12:35 PM
civichbcx's Avatar
JDM B16A's should only say "B16A", no A2 or A3 or A1.....
Go to this site and read this: (The very first paragraph under "What to look for")
http://tech.hybridgarage.com/tech/b16/index.html
Hybridgarage.com is a very credible site.
Modified by civichbcx at 1:47 PM 12/19/2005
