Valve cover studs !
Old Dec 17, 2005 | 07:56 AM
EG_Civic_Si's Avatar
Default Valve cover studs !
So how can I pull this bitch out with some common tools?? Or do I HAVE to go to a shop and have them drill it out? How much $ to drill it out?
Old Dec 17, 2005 | 08:05 AM
B18EG6's Avatar
Default Re: Valve cover studs ! (EG_Civic_GSR)
take the other 7 nuts off the valve cover studs. After the valve cover is off, you can use a normal deep socket to remove the broken stud.
cost = $0
Old Dec 17, 2005 | 08:07 AM
Default Re: Valve cover studs ! (B18EG6)
you ******* rule !!!
Old Dec 17, 2005 | 08:08 AM
B18EG6's Avatar
thanks!
i forgot, you'll need a new stud from honda (forgot to add that into the budget )
Old Dec 17, 2005 | 08:12 AM
dohcVTECeg2's Avatar
or junkyard
Old Dec 17, 2005 | 08:21 AM
Targa250R's Avatar
be professional
Just remember when you reinstall the new studs to torque them properly and do not overtighten - they only require 7 lb-ft of torque!
Old Dec 17, 2005 | 08:32 AM
Default Re: Valve cover studs ! (Targa250R)
8x1.25 is the THREAD size of the studs right? Can I just get new ones from napa or somewhere?
Napa = 1 Mile
Honda Dealership = 35+ miles + closed !
Old Dec 17, 2005 | 08:41 AM
Mr. JDM-GSR's Avatar
[QUOTE=
Napa = 1 Mile
Honda Dealership = 35+ miles + closed ![/QUOTE]
owned !
Old Dec 17, 2005 | 08:44 AM
B18EG6's Avatar
well, once the VC is off you will notice that its not just a stud. It has a flanged nut in the middle of the stud.
However, if I remember correctly, that stud holds no forces other than the VC support. 4 of the studs hold the cam caps down but that doesnt.
I suppose, if you absolutely HAD to, you could use a normal stud.
Old Dec 17, 2005 | 08:48 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18EG6 &raquo;</TD></TR><TR><TD CLASS="quote">I suppose, if you absolutely HAD to, you could use a normal stud.</TD></TR></TABLE>
So if I go to NAPA and ask them for a 8x1.25 valve cover stud for a 2000 Honda Civic Si...that will work?
I cant find my damn repair manual any where and dont want to buy a 6th one !
Old Dec 17, 2005 | 09:29 AM
I called the honda dealership which is 37 miles away...sigh...They have one in stock and only ONE !
*hops in car*
"Mad 3rd gear VTEC please get me there with the quickness !!!"
*stops halfway there to put oil in car due to it spitting out of broken stud*
OFF I GO !
Old Dec 17, 2005 | 10:07 AM
damn a honda dealership 35 miles away! sucks to be you mine is just like 10 mins
Old Dec 17, 2005 | 10:14 AM
Lewy. Dee Ayy's Avatar
Default Re: Valve cover studs ! (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote">damn a honda dealership 35 miles away! sucks to be you mine is just like 10 mins </TD></TR></TABLE> half a mile for me
Old Dec 17, 2005 | 11:45 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Until you can repair that,
You can take a piece of rubber hose with some RTV and slip it over
the broken stud to seal the hole temporarily..
kodylive
Sep 30, 2012 01:15 AM
ITR32
Jul 27, 2007 06:09 AM
plikit
Jun 4, 2007 06:56 PM
1 point 6
Nov 2, 2006 08:45 AM
Dopamine_44
Nov 13, 2001 01:27 PM
