CRX si 90-91 4 wheel disc - front rotors larger?
Old Dec 17, 2005 | 05:45 AM
sugarloafpkwy's Avatar
Default CRX si 90-91 4 wheel disc - front rotors larger?
Easy question. Are the front rotors on the 90-91 crx si the same size as other EF's? (9.5'').
I had a 90 crx si that stopped good and my new(tome) 91 civic si doesn't stop good. I know the drums aren't the issue.
Old Dec 17, 2005 | 05:53 AM
SVOboy's Avatar
Yes they are the same, and they did not come with drums ever, so unless someone gave you drums, I dunno.
Old Dec 17, 2005 | 09:31 AM
Targa250R's Avatar
be professional
Default Re: CRX si 90-91 4 wheel disc - front rotors larger? (sugarloafpkwy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sugarloafpkwy &raquo;</TD></TR><TR><TD CLASS="quote">Easy question. Are the front rotors on the 90-91 crx si the same size as other EF's? (9.5'').</TD></TR></TABLE>
The rotors are the same 9.5" pieces that came on DX/Si models, however the '90-91 CRX Si had unique front calipers that had a larger piston and took a different pad than the other cars with 9.5" front rotors.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I had a 90 crx si that stopped good and my new(tome) 91 civic si doesn't stop good. I know the drums aren't the issue.</TD></TR></TABLE>
There are many, many factors that can affect a vehicle's braking performance. What does "stopping good" mean to you? Can you elaborate?
Old Dec 17, 2005 | 12:40 PM
Default Re: CRX si 90-91 4 wheel disc - front rotors larger? (Targa250R)
the pedal is stiff and requires excessive effort to stop. Pretty much can't lock brakes above 10-15mph even if i stand on the pedal. It's kinda scarry to drive, if someone were to step out in front of my car in a parking lot i would hit them.
First guess would be booster but it's not. replaced it and the hoses/check valve. I know it's working cause the pedal sinks when you start the engine.
Replaced pads and rotors and MC for ***** and giggles. Bled the system. checked for leaks. I think maybe one of the hoses is restricted, i will replace with stainless lines.
I just wanted to make sure EFs have decent brakes before I replace with OEM stuff when I could be upgrading to larger brakes. I've heard ef brakes suck but my crx felt normal.
Old Dec 17, 2005 | 01:30 PM
Tyson's Avatar
either car stock should be fine braking performance.
Old Dec 17, 2005 | 03:04 PM
jlicrx's Avatar
Default Re: (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">Yes they are the same, and they did not come with drums ever, so unless someone gave you drums, I dunno.</TD></TR></TABLE>
90-91 Civic Si had drum brakes on rear - 90-91 CRX Si had discs
Old Dec 17, 2005 | 03:09 PM
SVOboy's Avatar
Aha, thanks a lot, never knew that difference existed.
nihad
Apr 2, 2007 08:46 PM
Ass$nyper
Apr 22, 2005 03:57 PM
ZeroTorque
Jan 15, 2005 12:02 PM
rice_classic
Jan 8, 2005 10:14 AM
Bontke
Jun 29, 2003 03:09 PM
