Hand Ported VS. CNC Ported Heads
Old Dec 17, 2005 | 01:54 AM
ALLphilthyDC2's Avatar
Default Hand Ported VS. CNC Ported Heads
I would like to know about anyone's thoughts on either or...the pro's and con's and what whould you rather prefer?
Old Dec 17, 2005 | 06:12 AM
marcin's Avatar
Default Re: Hand Ported VS. CNC Ported Heads (Philthy415)
something to think about.
a cnc is a copy machine. It will copy a good port of a shitty one just depends on what is programed into it.
m.
Old Dec 17, 2005 | 10:35 PM
dude_123's Avatar
CNC porting is consistent because its programmed to cut and grind on the same axis of the port; whereas hand port differs from port to port resulting in inconsistent flow, but with a person with great deal of porting knowledge, air flow consistency is very close.
Old Dec 17, 2005 | 11:24 PM
Aquafina's Avatar
Default Re: (dude_123)
Hand ported takes more time. Usually more expensive. Can be tailored to a specific cam.
CNC takes less time and is more consistent port to port. Can be tailored to a specific cam if you have $4,000 plus to spend (development, digitizing ports, etc). Only downside to CNC is it leaves machining marks, but these are usually smoothed out by hand afterwards.
Thats my knowledge on it.
Old Dec 19, 2005 | 11:55 PM
Default Re: (Aquafina)
thanks for the responses!
Old Dec 20, 2005 | 06:24 AM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">Only downside to CNC is it leaves machining marks, but these are usually smoothed out by hand afterwards.
Wouldn't you want that though? I mean, wouldn't that aid in turbulence helping to atomize the fuel better?
Old Dec 20, 2005 | 12:17 PM
Aquafina's Avatar
Default Re: (Black R)
To a point it could. If you know someone who CNC ports heads, ask if you can see one before they hand finish it. The marks are much bigger than you would like.
A.E Motoring
105
Mar 30, 2013 01:02 PM
Combustion Contraption
52
May 30, 2007 02:22 PM
ekim952522000
Mar 29, 2006 03:38 PM
xxxxspdrcr
Jun 19, 2003 10:30 PM
Balls
Mar 28, 2002 01:48 PM
