zc swap???
ok i searched first and read through all the recent posts. what all exactly do i need to put a zc in a 89 crx si. i already have the motor, but thats all. thanks alot.
the motor is all you really "need"... it bolts up to your Si tranny and to the stock motor mounts, stock exhaust manifold fits as well...
but since you got the motor out might as well do clutch, flywheel, timing belt, etc....
oh, you're prolly gonna need the upper radiator hose from an 89 integra.. cut off a couple inches and it fits fine....
check out the 4g section on the hybrid board, I think theres a tiny bit of wiring you have to do, pretty sure its swappin wires on the TPS...
hth
hth
I live down in Knoxville and I'm starting my swap on Monday. Where did you get your motor from? Mine is from Evan's. You do need to unplug two of the wires from the dist to put in the exhuast cam sensor.
Hope it all goes well for you.
Brian G.
Brian G.
check out this site it will help you with your swap http://thenew.gamesbbs.com/~dmoore/zc-phase3.htm
crex23
Aug 13, 2004 05:21 AM
thaiphob
Mar 12, 2003 06:49 AM
