95 accord LX Check engine light
Old Dec 16, 2005 | 05:22 PM
oluva's Avatar
Default 95 accord LX Check engine light
check engine light wont turn off took it to the shop and they said it was o2 sensor after the made me spend money they realized it wasnt the problem and they suggested that i take it to the dealership, possibly a ECU problem of what not. I changed the exhaust manifold to some 421 headers and ever since that damned light wont turn off. Any suggestions?
Old Dec 16, 2005 | 05:34 PM
P_Adams's Avatar
Default Re: 95 accord LX Check engine light (oluva)
Generally speaking, what your repair shop told you is true (although I think they tried a "Hail Mary" repair on the hopes of repairing it.
It's common that when the ECM (Engine Control Module) goes stupid, it's indicated thru the "service engine soon" lamp by either staying on fixed (all the time) or doesn't go on at all. If the system can 'self diagnose' the lamp will flash a code.
A trip to either a more knowledgeable shop or a local Honda dealer is in order
P
Old Dec 16, 2005 | 08:22 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oluva &raquo;</TD></TR><TR><TD CLASS="quote">check engine light wont turn off
What trouble code does it have stored?
Old Dec 17, 2005 | 12:28 AM
oluva's Avatar
Default Re: 95 accord LX Check engine light (Chiovnidca)
I used the paper clip trick and the code flashed 41 which is the oxygen sensor heater
Old Dec 17, 2005 | 06:28 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oluva &raquo;</TD></TR><TR><TD CLASS="quote">I used the paper clip trick and the code flashed 41 which is the oxygen sensor heater</TD></TR></TABLE>
If the sensor itself is good, (it can be checked with an ohm meter) then the wiring and connectors would be a good place to check next.
Hondalina
Dec 13, 2010 02:39 PM
lilchin
Mar 14, 2007 02:10 PM
B16Jacques
May 13, 2006 09:32 AM
hiphop101
Aug 13, 2005 08:56 PM
