??? intake manifolds
Old Dec 16, 2005 | 05:21 PM
si0385.'s Avatar
Default ??? intake manifolds
can i use the d15b manifold and the throttle body from the d15b... and still keep it wired obd0... its not the wireing im having problems with its the vacuum lines... i also cant get the damn thing to idle at less than 1700 rpm and the idle adjustment screw is all the way in...
in the si manifold there is three vacuum ports on the manifold and on the throttle body there is a kind of diaphram... the d15b manifold has 1 manifold vacuum port and one ported vacuum port and no diaphram on the t/b
does the map sensor need to be hooked up to a manifold vacuum or a ported vacuum... anybody that has this setup that is running right i would greatly appreciate your help
Modified by jaydeum4lyfe at 6:33 PM 12/16/2005
Old Dec 17, 2005 | 10:32 AM
d16vtecx's Avatar
Default Re: ??? intake manifolds (jaydeum4lyfe)
i had the same problem nwith my d15b into 88 hf swap
just take out that vacuum assemble on the firewall that has the map
use the map sensor on the d15b tb then you should have one line form tb to evap canister
that should be all
tempsohc
Jun 19, 2011 06:06 PM
Devo94ac
Apr 9, 2010 07:30 PM
LUKE 92 GS-R
Jun 18, 2008 06:17 PM
juanchoenuncrx
Dec 26, 2007 05:03 PM
SUMORex
Mar 24, 2002 05:19 PM
