Are Oil coolers standard on B16's?
I'm working on swapping a B16 and instead of the oil filter mounting right to the block, it seems to mount to a 'spacer' which is about 2" thick. From this spacer, there are 2 hoses. One runs to the main coolant line that runs along the back of the motor and eh I forget where the other goes, but it appears as if it forces coolant in one side and out the other, through a liquid to liquid oil cooler. I'll get some pics when I can.
I presume the engine came from an XSi because it is a P3 ECU (I think)
So, I guess my question really is this- do Oil coolers come only on certain motors or what? Do they only come on the JDM Integra?
Thanks
Brian
Modified by 99CivicSiBrian at 6:43 AM 12/17/2005
Thanks
Brian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGDC2CIVIC »</TD></TR><TR><TD CLASS="quote">94-95 gsr's came with them and i beleive all itr's and h22's</TD></TR></TABLE>
USDM or JDM, cause my friends b18c doesn't have an oil cooler.
Well his doesn't have it. I've been under that car many times and never seen any lines going to the oil filter area, except for the oil feed line. I'm sure you could all figure out what that is for.
B16s do have an oil cooler (cool with coolant though), it is not the type that looks like a trans cooler or radiator, it is the steel piece you screw your oil filter onto. Next time you change your filter look at the coolant lines going to that piece you screw the filter on that is the cooler. I have two b16's sitting here one in my car and the other in my garage.
What the thread started descriped is the cooler and i am 99% sure all vtec motors come with it (don't kow about d-series). But i have done plenty of swaps and seen it every time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 »</TD></TR><TR><TD CLASS="quote">Well his doesn't have it. I've been under that car many times and never seen any lines going to the oil filter area, except for the oil feed line. I'm sure you could all figure out what that is for.</TD></TR></TABLE>
yeah i need to remove my cooler and replace it with a oil feed line, nice trade-off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si »</TD></TR><TR><TD CLASS="quote">only motors ive seen with something similar are older accords, early 90s
my b16 does not have that</TD></TR></TABLE>
Your wrong noob, look at where your oil filter screws on there are coolant lines coming from the rear coolant tube to the unit you screw the filter on to. That is the oil cooler, its not much but it does the job.
https://honda-tech.com/zerothread?id=1083588
https://honda-tech.com/zerothread?id=312354
as i said before my b16 doesnt have one either, its a 95, but my 95 gsr and h22 do have them. so im gonna say that not all b16's have the cooler, and i do know what/ where they are
Modified by EGDC2CIVIC at 10:29 PM 12/16/2005
The RSX Type S motor has one. I remember reading that if you swap to a K24 block you have to either block the one port on the head or tap out the port. . . something like that.
But yeah I'll take some pics and try to figure out how to post them up here. BTW I wanna say that this site has an amazing amount of responders/viewers. I just posted my question yesterday and I come back to find it on the bottom of the 2nd page! Thats amazing!
Ok thx.
B
Ok thx.
B
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboxsi »</TD></TR><TR><TD CLASS="quote">Your wrong noob, look at where your oil filter screws on there are coolant lines coming from the rear coolant tube to the unit you screw the filter on to. That is the oil cooler, its not much but it does the job.</TD></TR></TABLE>
USDM B16As do not have an oil cooler.
