Adjusting a blow off valve?
Old Dec 16, 2005 | 05:02 PM
TurboEKcoupe's Avatar
Default Adjusting a blow off valve?
does anyone know how to adjust a blow off valve? i just got my turbo installed and the guy told me i might have to adjust my blow off valve any input would be appreciated
Old Dec 16, 2005 | 05:03 PM
jay_cue's Avatar
Default Re: Adjusting a blow off valve? (TurboEKcoupe)
depending on what brand of blow off valve you have, but there's normally a screw o nthere that you can tighten or loosen
teamvirus's Avatar
My car breaks a lot!
should be a nut on to of the bov...try turning it..
Old Dec 16, 2005 | 05:10 PM
yea theres a nut but im not sure which way to turn it..i want it to be louder
Old Dec 16, 2005 | 05:52 PM
jay_cue's Avatar
Default Re: (TurboEKcoupe)
the nut is to adjust how loose, or tight it holds. not for volume. if you turn up the boost, it will blow off louder though.
Old Dec 16, 2005 | 06:38 PM
SWC's Avatar
SWC
Default Re: (whal3_p3nis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whal3_p3nis &raquo;</TD></TR><TR><TD CLASS="quote">the nut is to adjust how loose, or tight it holds. not for volume. if you turn up the boost, it will blow off louder though.</TD></TR></TABLE>
Do NOT turn up the boost just for blow off sound louder. It will NOT be louder. The BOV has to set properly on one setting for your boost level. If it's too loose, the boost will be leaking. If it's too tight, you will get flutter sound and damage to your turbo. Do it right!
Normally turn clockwise for tighten(harder), counterclockwise for loosen(softer).
Modified by SWC at 9:31 PM 12/16/2005
Old Dec 16, 2005 | 07:48 PM
x2gold's Avatar
Default Re: (SWC)
also, some require washers - turbo XS.
Old Dec 16, 2005 | 09:52 PM
wdstkd16's Avatar
Default Re: (SWC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SWC &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by SWC at 9:31 PM 12/16/2005</TD></TR></TABLE>
mine fluters a bit, i got the Greddy Type S, so i should lossen it then..sweet deal
Old Dec 17, 2005 | 12:37 AM
jay_cue's Avatar
Default Re: (SWC)
by all means i'm not suggesting that he should increase boost just to blow off louder, but he's just wanting to blow off louder. well in my experience with a turbo'd eclipse, the more i boosted, the louder it blew off. i didn't simply increase boost just to blow off louder however. my motor was setup to handle more boost. i didn't just get boost happy.
Old Dec 17, 2005 | 07:35 AM
MikeD718's Avatar
with your car at idle turn the screw out, to loosten the valve. you should feel air coming from the valve, then start tightening the valve, you might have to rev the engine a bit to change the vaccum pressure to re-set the valve. turn it untill right after you feel the air stop comming out of the valve and tighten the jam nut. thats how i did my blitz DD BOV and it worked fine.
Old Dec 17, 2005 | 08:16 AM
dohcVTECeg2's Avatar
Default Re: (MikeD718)
righty tighty. lefty loosey
RoB316
May 31, 2007 06:16 PM
JFG Kevin
May 12, 2004 03:44 PM
streetracinghn
Nov 23, 2003 06:21 AM
VTC_CiViC
Jul 2, 2002 10:11 AM
