Wierd headlight problem...
Old Dec 16, 2005 | 03:28 PM
j87w's Avatar
Default Wierd headlight problem...
I have a 97 Honda Civic EX with a 97 Civic CX Harness in it. The last owner had a problem with the passenger headlight not working. I have checked the bulb, fuses, ect. I noticed that when the driver headlights not plugged in it works. Then when you plug the driver one in the passenger stops working. Any Ideas. I would really like to get this fixed!
Old Dec 16, 2005 | 04:35 PM
99CivicSiBrian's Avatar
B A N N E D
Default Re: Wierd headlight problem... (j87w)
This is my first post!
But anyway, I think that one of the terminals inside one of the headlight plugs may have been switched. Get the multi-meter out and test all the wires of the plugs against what the Helms manual says it is supposed to be.
Hope that helps. It is my first post after all.
Ok last time I say that.
B
Old Dec 16, 2005 | 07:02 PM
j87w's Avatar
Default Re: Wierd headlight problem... (99CivicSiBrian)
Do you know how to check the headlights for power? The weird thing about this is that, both headlights have power and I know for sure they have grounds. I just cant figure out why it only sometimes works.
Old Dec 16, 2005 | 09:36 PM
j87w's Avatar
Ok, now its back to same old problem. The driver low beam works and both highbeams work. Both bulbs are good, fuses are good, ect. The ground is good for the passenger headlight as we got it to turn on for a second.
Come on someones gotta have some info on this...
Old Dec 18, 2005 | 10:41 AM
j87w's Avatar
Bump it up...
Old Dec 19, 2005 | 01:51 PM
j87w's Avatar
Come on someone help me troubleshoot.
Old Dec 20, 2005 | 10:49 AM
j87w's Avatar
Anyone...??
Old Dec 22, 2005 | 12:02 AM
j87w's Avatar
Late night H-T's?
Old Dec 22, 2005 | 12:13 AM
riceburnerryan's Avatar
i suggest driving with your brights hahaha ... no im kidding
i would say, go thru again and just to be sure that the grounds are ok ...
Old Dec 22, 2005 | 11:04 AM
j87w's Avatar
Default Re: (riceburnerryan)
Yea man, Ive already checked my grounds. My grounds are good. Someone help me out here.
Old Dec 22, 2005 | 11:13 AM
520_Motorsports's Avatar
Default Re: (j87w)
you have a short in your headlight wiring you need to trace the problem from one side to the other you should have a break in the wiring some where between the two headlights!! hope that helps
Old Dec 22, 2005 | 11:29 AM
j87w's Avatar
Default Re: (SlowAzEg)
So would It be best to just order a new headlight harness?
Old Dec 27, 2005 | 07:50 AM
B A N N E D
Default Re: (j87w)
it might be dumb, but switch the bulbs. . . just to be sure the bulb is ok.
B
Old Dec 27, 2005 | 01:21 PM
j87w's Avatar
Default Re: (99CivicSiBrian)
Haha, I've already tried it.
Old Dec 27, 2005 | 01:30 PM
kleanlscivic's Avatar
Default Re: (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">So would It be best to just order a new headlight harness?</TD></TR></TABLE>
probaly do this after you run down the wires to see if there is a break, sounds like it might have gotton cought in something and making a short somewhere good luck
Old Dec 27, 2005 | 02:47 PM
j87w's Avatar
Default Re: (kleanlscivic)
I'm alright with electrical testing but I have no idea how to test these headlights. Anyone got some info?
Old Dec 27, 2005 | 07:15 PM
B A N N E D
Default Re: (j87w)
sheeeit.
I had to replace the plug on mine once. . . maybe a terminal is bad inside your plug? something goofy like that I guess.
B
Old Dec 28, 2005 | 12:02 AM
j87w's Avatar
Hmmm, still waiting for someone that knows how to trace out the wiring in these headlights.
Old Dec 29, 2005 | 04:12 AM
Default Re: (j87w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">Hmmm, still waiting for someone that knows how to trace out the wiring in these headlights. </TD></TR></TABLE>
why not just follow the wiring from the headlights, easiest way to trace the wiring
Old Dec 30, 2005 | 12:51 AM
j87w's Avatar
What do you mean?
Does anyone have the printouts from a FSM for this? If I had a FSM I wouldnt have a problem here.
Old Dec 30, 2005 | 02:18 AM
Redlite's Avatar
Default Re: (j87w)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j87w &raquo;</TD></TR><TR><TD CLASS="quote">What do you mean?
Does anyone have the printouts from a FSM for this? If I had a FSM I wouldnt have a problem here.</TD></TR></TABLE>
he means, put your hand on the headlight wire, and follow it until it goes into the fuse box. Try putting the tester inside of the plug and see if all 3 prong holes have current
Old Jan 1, 2006 | 06:14 PM
j87w's Avatar
Default Re: (Redlite)
Does anyone know what color is the wire that is low beam for the passenger side headlight?
ant13
Aug 26, 2012 05:23 AM
PinoyDelS0l
Oct 1, 2011 01:02 PM
hotaccord243
May 29, 2008 01:00 PM
soberstan
Oct 19, 2004 04:08 PM
