ef HELP 88
Old Dec 16, 2005 | 11:53 AM
civic889802's Avatar
Default ef HELP 88
HEY WERE CAN I GET AXELS FOR B16A1 N THE SHIFT LINKAGE
N WOUNDERING I HAVE A 88 DUAL POINT DO I STILL HAVE TO MODIFY ANYTHING OR I JUST PUT THE NEW HARNESS N THATS IT THANKS FOR HELP
Old Dec 16, 2005 | 12:46 PM
R_type's Avatar
Default Re: ef HELP 88 (civic889802)
THIS HAS PROBABLY BEEN COVERED AT LEAST A KABAZILLION TIMES............... !!!!!!!!!!!!SEARCH!!!!!!!!!!
Old Dec 16, 2005 | 01:18 PM
Targa250R's Avatar
be professional
The proper axles will depend on which intermediate shaft you use. If you have a '90-93 Integra intermediate shaft, you can use '90-93 Integra axles. If you have a Y1 intermediate shaft, I suggest getting a '90-93 Integra intermediate shaft so you can use '90-93 Integra axles.
For shift linkage, Hasport sells what you need. If you want to DIY, you'll need to cut and weld.
For the wiring harness, you'll have to convert your harness to MPFI and then wire in the VTEC. If you don't want to DIY, this can be done for you by Rywire.
ej1project
Mar 28, 2010 08:03 PM
EF9-CIVIC
12
May 17, 2007 05:57 PM
.Grimace
Sep 29, 2005 08:28 AM
XANDER-666
Oct 7, 2002 12:04 PM
a88crxsir
Aug 25, 2002 04:54 PM
