Replacing Valve cover gasket and spark plug seals..
i got some oil on my spark plugs, so im gonna replace the seals, ( the valve cover gasket isnt leaking though)
do i need to take off the timing belt cover to take off the valve cover?
last time i unbolted the 2 nuts, the ground,and the spark plug wires and the cover wouldnt come off
should i try lifting it with a screw driver
in the left side of the diagram below #14 hold the valve cover down and there are four of them. In the right side of the diagram #12 holds the valve cover down and there are five of them.
The valve cover may be a little stuck after removing the nuts/bolts, just gently pry it up with a screw driver.
Also, you should note which year/trim level you have and also list the motor if it has been swapped.
I believe your motor is a F22A1
You valve cover should look like the diagram below.
As you can see part #8 is the nut that holds the vavle cover on. There are two on the top front and two on the top back (between the spark plug tubes).
standbackimapro
Apr 29, 2006 05:38 PM
standbackimapro
Jan 20, 2006 09:55 AM
