Couldn't find a definitive answer: Adding fuel with VAFC
Old Mar 16, 2002 | 02:52 PM
Toda Party's Avatar
Default Couldn't find a definitive answer: Adding fuel with VAFC
yeah i know its been beaten to death but here's my ?
VAFC and no FPR - can you add more fuel than stock?
my impression is that u can add fuel that you took away with the VAFC, but you can't add any more than stock at a given point.
please edumacate me
Old Mar 16, 2002 | 03:22 PM
FSTASNTZ's Avatar
Default Re: Couldn't find a definitive answer: Adding fuel with VAFC (Toda Party)
You can add fuel and subtract fuel. But, in my experience, it is not as consistant as when you subtract fuel. Hence why we all suggest using a AFPR and the V-AFC. There is a point where you can add additional fuel and it makes no difference, but I forgot where I ran into that.
Jason
Old Mar 17, 2002 | 12:27 AM
JaeOne3345's Avatar
Default Re: Couldn't find a definitive answer: Adding fuel with VAFC (FSTASNTZ)
vafc will help tune in increments as far as your fuel maps..but u need fpr for primary fuel pressure.
Old Mar 17, 2002 | 12:36 AM
EGtoR's Avatar
I think you can add it to a certain point, but after you max out the map, it won't add anymore. I would say buy a FPR, rise the pressure and then use a VAFC to lean it out where it needed.
Old Mar 17, 2002 | 01:39 AM
JSIR's Avatar
New User
I think you can get about 10% more fuel in most cases. Basically watch your vacuum reading at WOT once it reads 0 that is the limit of any more fuel increase as the MAP signal can't be modified any further. So increase fuel in small increments until the Map signal is basically 0. that should be the limit of the fuel increase.
vietshinobi
Jul 10, 2004 12:10 AM
BLK99VTECR
Oct 23, 2003 12:07 PM
MrSmith
Feb 7, 2002 08:16 PM
Mike95lude
Oct 10, 2001 10:53 AM
ninjaman
Aug 13, 2001 01:41 PM
