CRX Swappin?
Old Dec 15, 2005 | 11:52 PM
bjfisher's Avatar
Default CRX Swappin?
i know this has been covered,but i just came across a good deal on a crx,and have very little time to pick it up or let it go,soooo reeealll quick....
i have a complete gsr swap(mounts,linkage,axles,wiring,ecu,EVERYTHING)ou t of my totalled 95 gsr OBD1.now,will this mount directly into a 90 crx dx with the stock gsr mounts?the only problem i see is the car being obd0,so i figure the ONLY thing i will need to purchase is an obd0-obd1 conversion harness (unless you can tell me another way to do it).
thanks for the quick help guys!
Old Dec 15, 2005 | 11:55 PM
crxnj's Avatar
Default Re: CRX Swappin? (bjfisher)
Nah,,you need a b-series mount kit..hasport,hcp,place racing,arizonarace machine,ebay mounts,etc..Also your dx only has 2 injectors (dpfi),,You have to convert the harness to (mpfi) 4 injectors..As well as converting to obd1..And you can use the integra shft linakge but you have to shorten it or you can buy a pre made one ..(hasport,hcp,place racing ,etc..) After that, you just add the wires in your harness for vtec and add the wires for the iab's assuming you still have the stock gsr intake manifold..And if you use the obd1 injectors you dont need to use a resistor box..
EDIT :: ****, almost forgot if you use the hydro tranny off the 95 gsr, you have to get the hasport cable to hydro mount kit or convert some other way..Or find a cable b-series tranny
Old Dec 16, 2005 | 12:00 AM
bjfisher's Avatar
oh ok thanks very much....i think ill pass up this deal then,little more work than i have time to do right now,not to mention money wise....now i know why i stick with 92+ civics haha
Old Dec 16, 2005 | 12:02 AM
crxnj's Avatar
Default Re: (bjfisher)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bjfisher &raquo;</TD></TR><TR><TD CLASS="quote">oh ok thanks very much....i think ill pass up this deal then,little more work than i have time to do right now,not to mention money wise....now i know why i stick with 92+ civics haha</TD></TR></TABLE>
But a gsr powered crx is more fun then a 92+ civic..
Old Dec 16, 2005 | 12:16 AM
bjfisher's Avatar
i wont deny that,but i dont have the time or money to do that right now
Old Dec 16, 2005 | 06:15 AM
HT Chaplain's Avatar
Loved
You dont have to switch to obd1. You can use b16a injectors and distributor and get a aftermarket IM and a PR3 ECU and your good to go Thats what i did
Old Dec 16, 2005 | 06:25 AM
CRX Toad's Avatar
Default Re: (HT Chaplin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HT Chaplin &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to switch to obd1. You can use b16a injectors and distributor and get a aftermarket IM and a PR3 ECU and your good to go Thats what i did</TD></TR></TABLE>
The swap in a CRX will be well worth it.
Old Dec 16, 2005 | 09:44 AM
Boosted Chemist's Avatar
its better to go obd1 for future tuning capabilities
i would stick with all your obd1 hardware and dish out a 100 bucks for a harness, you thank me later
Savtec-rex
Mar 4, 2014 06:40 PM
shortA25
Jan 21, 2011 12:35 PM
Str8JDMCRX
Oct 29, 2009 11:27 AM
tavius44
Nov 2, 2006 12:46 PM
FBEF20
Apr 10, 2006 07:08 AM
