Manual window crank removal
there is a little metal clip that hides behind the window crank that pins it to the regulator. what u do is get a little pick and pull it right out and off comes the handle
yep, that will do the trick.
just look under the crank, there's a small rectangular shaped opening just enough to insert the flat tip of the screw driver. slowly pry that U-shaped clip that locks the crank/handle from the shaft.
see the pic. sorry for my poor illustration
From: I told you to wait in the truck in Texas, United States
You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip..
To re-install,position the clip as shown in the second picture,
Hold the handle in the postion you want it and give it a slight smack
and it will pop right on..
[QUOTE=88DXCRX]You can also remove the clip with a grease rag..
Drag it through and catch one end of the clip QUOTE]
I was just about to suggest this! Works like a charm.
Btothe3rdDegree
Apr 19, 2004 03:22 PM
okman16
26
Nov 9, 2003 12:48 PM
slvrcivic97
Jul 15, 2003 10:38 AM
