Please give me some insight on my winter motor build.
Old Dec 15, 2005 | 10:02 PM
jaydmcrx's Avatar
Default Please give me some insight on my winter motor build.
I have a couple questions, or constructive critism i guess you could say on my upcoming build i would like to do with my itr motor this winter.....
here is what i have as of right now.
Jdm itr head..........
portflow valve springs
portflow retainers
jun stage2 intake cam
ctr exhaust cam
srr cam gears
aebs intake manifold
ported 65-70mm itr throttle body
outlaw engineering gasket kit
Jdm itr block
itr crank/rods/pistons
freshly hoaned
new acl rod/main/thrust bearings
arp rods bolts (9mm bolts)
arp head studs
I am looking to ditch the bottom end, minus the crank, and run 85mm cp's 12.5:1, along with cunningham or crower billet rods, and ditch the cams for some skunk2 pro2's. With the bolts on i have as of right now, minus the header, do you think the stock itr head will hurt me in my goal of making 225whp? Any suggestions would be great.
I was also looking for a good header suggestion. I was going to go with a custom lovefab, or an rmf.
this is all going in a crx, if it matters, and i was just looking for suggestions. All will be tuned with hondata.....The car is primarly going to be for road racing/fun street car. And the occasional drag strip.
Old Dec 15, 2005 | 10:12 PM
jaydmcrx's Avatar
This is still in the very early stages of me deciding what to do, so it may change, this is just a rough layout of what im thinking i may do. So suggestions are great.
Old Dec 16, 2005 | 12:17 AM
Chase's Avatar
Default Re: (jaydmcrx)
You should do more headwork. Like port the head....that alone would get u well over 200+++++hp as it is. It will be a beast if u do the 85mm too!!!!!!
Oh port the Intake manifold as well.
Old Dec 16, 2005 | 04:28 AM
jaydmcrx's Avatar
Thanks for the advice. I think it should be fun. I was thinking if i did head porting that i should go with dpr, or portflow.
Old Dec 16, 2005 | 12:47 PM
Chase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydmcrx &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the advice. I think it should be fun. I was thinking if i did head porting that i should go with dpr, or portflow.</TD></TR></TABLE>
Yeah or RLZ or Alaniz If i remember the portflow flowed less than the RLZ, Alaniz, DPR
Old Dec 18, 2005 | 03:10 PM
kris83's Avatar
rofl sean hella build on the way.
Old Dec 18, 2005 | 08:06 PM
sheepey's Avatar
Default Re: (EF8kid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8kid &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah or RLZ or Alaniz If i remember the portflow flowed less than the RLZ, Alaniz, DPR </TD></TR></TABLE>
Rocket Motorsports is also another great head service place!
Old Dec 19, 2005 | 12:40 PM
Chase's Avatar
Default Re: (sheepey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheepey &raquo;</TD></TR><TR><TD CLASS="quote">
Rocket Motorsports is also another great head service place! </TD></TR></TABLE>z
Yes them as well Theres alot of good ones....
CRVTEC0WNZJ00
44
Jul 26, 2006 09:20 AM
jaydmcrx
Dec 7, 2005 06:45 PM
jaydmcrx
Sep 9, 2005 07:11 AM
jaydmcrx
Apr 19, 2005 10:32 AM
