Subframe tear-out question
Ok, here's the deal. I'm looking to do a fairly mild street suspension setup. To that end, here is the setup I am planning on:
H&R OE Sport springs (280 lb/in f, 180 lb/in r) ~.75" drop f/r
KYB GR-2 shocks
EX front sway bar
Right now I have a GS-R rear sway, but I just bought a 19mm ST rear sway.
With these spring rates and a 19mm bar, will tear-out be a real concern? Car will never be tracked and will see hard street duty at best.
Should I just drop another $200 on the ASR brace? Or will a simple rear tie fix things?
KYB GR-2 shocks
EX front sway bar
Personally I have no Idea!
But IMO... better be safe than sorry...
From what i've read, the rear subframe isn't the strongest peice of the car... and an ASR brace would really help... it also acts as a tie-rod... doesn't it?
Plus its bling!!! LOL
also its not 200! its only 180... plus shipping
passwordjdm has em for 179.9x or sumthing like that...
hope that was helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shifty35 »</TD></TR><TR><TD CLASS="quote">Ok, here's the deal. I'm looking to do a fairly mild street suspension setup. To that end, here is the setup I am planning on:
KYB GR-2 shocks
EX front sway bar
Should I just drop another $200 on the ASR brace? Or will a simple rear tie fix things?</TD></TR></TABLE>
youll run a pretty decent chance of it tearing out. youre spring rates are so low that your swaybar is going to be doing most of the work during cornering. if you already have the springs, invest in the subframe brace.
KYB GR-2 shocks
EX front sway bar
i've tore mine.
even w/ "brackets"... at that point (back then) there was no ASR brace...
I'm rocking the CTR frame right now... but in ur case, i say drop the $ for the brace. you WOULD NOT be sorry...
trust me.
however, in the case that ur frame still tears w/ the brace (which is a very minimal slim-*** chance, like we're talking about 0.01%) then ur SOL... weld the bitch until u r fed up welding it and rock the CTR frame
(CTR frame is not expensive $200CAD shipped no problem, u do the conversion to USD) but labour i can tell u is ($1000CAD)...
cheers.
trust me.
(CTR frame is not expensive $200CAD shipped no problem, u do the conversion to USD) but labour i can tell u is ($1000CAD)...cheers.
I am not 100% sure if there is a chance of tear out, or ever a small chance, but for street use you don't need to fork out $200 for a kit. Check users BSQ and Beaks kits, they work well. I use the BSQ with a 23mm sway bay, but much stiffer springs and shocks, on a track, and have not had a tear out problem. Before that I ran a 22mm rear sway bar with ITR shocks and springs (pretty soft and similar to H&R OE rates) with the BSQ kit and had no problems either.
i have the beaks kit, when i was chisling the old nut off my subframe started to tear about 1/4" at the bolt hole. im not sure what i should do know, im thinking getting the brace and hoping theres no other problems. ill try to get some pics
I had pics on my computer but the 'puter' fried last year
lost everything... old pics car show pics... the models EVERYTHING.
anyhow, i had the body shop weld it on and luckily the alignment result came out "spot on" so everything was fine. PHEW!
lost everything... old pics car show pics... the models EVERYTHING.anyhow, i had the body shop weld it on and luckily the alignment result came out "spot on" so everything was fine. PHEW!
VarTheVar
35
Jun 23, 2018 05:23 PM
