weight difference between aluminum and aluminized steel?
Old Dec 15, 2005 | 09:18 PM
paulzy's Avatar
Default weight difference between aluminum and aluminized steel?
I found the weight of 1ft. of 4"OD 16 gauge aluminum from burns stainless, which was .95 pounds, but can't find the weight of aluminized steel in the same thickness and OD. Does anybody happen to know what it is? I'm trying to see if the extra cost of the aluminum is worth the weight savings over the aluminized steel for an exhaust
TIA
Old Dec 15, 2005 | 10:29 PM
k24em2's Avatar
Default Re: weight difference between aluminum and aluminized steel? (paul vang)
It's fairly significant. I don't know the exact numbers, but aluminized steel and aluminum are vastly different materials.
Old Dec 15, 2005 | 11:39 PM
Extent's Avatar
I thought that Aluminized steel was just mild with a thin aluminum coat, so it would weigh the same as mild.
Old Dec 15, 2005 | 11:49 PM
redawdcrx's Avatar
you would not use the same thickness aluminized steel would be thinner then steel because of rusting. you are using it for exhaust?
Old Dec 16, 2005 | 09:00 AM
Finest's Avatar
IMO, an aluminum exhaust isn't worth it just to cut down on weight. You can shed weight elsewhere, which is technically free!
BTW, what kind of welding setup do you have now?
Old Dec 16, 2005 | 09:06 AM
KFMRC's Avatar
aluminum is basically 1/3 the weight of steel
Old Dec 16, 2005 | 10:54 AM
beepy's Avatar
I would like to see an update from the few people that tried aluminum exhausts. My guess is that they cracked to **** after about 6 months.
If you want to go light, just use 20 gauge stainless. You will save 20 pounds with an aluminum exhaust, but like said above, you can save 20 pounds from somewhere else.
Old Dec 16, 2005 | 04:43 PM
tony1's Avatar
Default Re: weight difference between aluminum and aluminized steel? (beepy)
When you're building a race car, 20lbs is alot!
Old Dec 16, 2005 | 09:08 PM
paulzy's Avatar
thanks guys....
I've have the same setup as before....180SD, sold the millermatic 135 so I can save up for a 210
Old Dec 16, 2005 | 09:13 PM
beepy's Avatar
Default Re: weight difference between aluminum and aluminized steel? (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">When you're building a race car, 20lbs is alot! </TD></TR></TABLE>
If it's a race car, you don't use a full exhaust, and aluminum would melt in any case.
Old Dec 16, 2005 | 09:16 PM
tony1's Avatar
Well, I consider a SFWD car a "race" car, and they have to run a full exhaust. And aluminum will not melt, it's been done plenty of times...
Old Dec 17, 2005 | 01:47 PM
paulzy's Avatar
I just might go aluminum because my cage is mild and that will probably offset the 30-40 pounds over the chromoly vs mild steel
Yes, I consider a SFWD car a race car as well seeing that it's similar to the hotrod class cars back in the good ol' days aside from a little more interior and body panels
Old Dec 18, 2005 | 12:08 PM
ComposiMo's Avatar
Default Re: (paul vang)
When i did the 4" aluminum exhaust on Fergusens car, i was able to hold it up in the air and twirl it around like a baton... lol.. i'd definitely run a full aluminum exhaust in a SFWD car. Its worth every pound
Old Dec 18, 2005 | 12:47 PM
paulzy's Avatar
Default Re: (ComposiMo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComposiMo &raquo;</TD></TR><TR><TD CLASS="quote">When i did the 4" aluminum exhaust on Fergusens car, i was able to hold it up in the air and twirl it around like a baton... lol.. i'd definitely run a full aluminum exhaust in a SFWD car. Its worth every pound </TD></TR></TABLE>
lolz, I think Donatello has found a replacement for a wooden bo staff
Old Dec 28, 2005 | 09:06 AM
Justin Olson's Avatar
What thickness aluminum do you guys run for aluminum exhaust? Do you just use v-band clamps to attach the aluminum exhaust to the steel downpipe?
Regards,
Justin
Old Dec 28, 2005 | 09:11 AM
RMF
Guest
Posts: n/a
Default Re: (KFMRC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KFMRC &raquo;</TD></TR><TR><TD CLASS="quote">aluminum is basically 1/3 the weight of steel </TD></TR></TABLE>
Yes he is correct alum is 1/3 the weight of steel .And Magnesium is 1/3 the weight of Alum.
Modified by RMF at 10:43 AM 12/28/2005
Old Dec 28, 2005 | 09:27 AM
Default Re: (Justin Olson)
Cheap prices on thicker walled stuff:
http://www.globaltecheng.com/P...uct=1
Also, you can buy aluminum/steel v-band combinations here:
http://www.youngsperformance.c...20267
gizzmo222
Dec 2, 2010 02:57 PM
743power
Welding / Fabrication
May 25, 2005 04:21 PM
servion
Feb 21, 2005 09:31 AM
2fknlo
Feb 16, 2003 02:24 PM
